H22 Euro r
Old Jul 24, 2004 | 09:08 PM
crj_lll's Avatar
Default H22 Euro r
Is the H22 Euro r an open or closed deck?
Also, where does the Ero R find it's Extra power and torque from or specificaly the 10 lb ft tq?
Assuming the H22 Euro R has an open deck, the remaing a would a closed deck be able to be swapped into place instead of an open deck?
Old Jul 24, 2004 | 09:24 PM
Matgallis's Avatar
Default Re: H22 Euro r (crj_lll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">Also, where does the Ero R find it's Extra power and torque from or specificaly the 10 lb ft tq?
</TD></TR></TABLE>euro r manifold for one.
Old Jul 24, 2004 | 09:28 PM
crj_lll's Avatar
Default Re: H22 Euro r (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">euro r manifold for one.</TD></TR></TABLE>
So a Euro r Manifold on a Type S will yeild 10 llb ft tq?
Old Jul 24, 2004 | 09:34 PM
Matgallis's Avatar
So a Euro r Manifold on a Type S will yeild 10 llb ft tq?</TD></TR></TABLE>I dunno, but the manifold is just one of the factors. I know it's different than a regular h22 manifold. I'm sure there are other factors. I just don't know them
Old Jul 24, 2004 | 11:39 PM
satan_srv's Avatar
A Euro-R makes 2 count'em 2 more foot pounds of torque than a regular JDM h22a..not 10
Old Jul 25, 2004 | 07:38 AM
Kal's Avatar
Kal
Default Re: H22 Euro r (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">A Euro-R makes 2 count'em 2 more foot pounds of torque than a regular JDM h22a..not 10</TD></TR></TABLE>
lol, 10ft/lbs is a lot now that i think of it for a Honda... couldn't have been 10..
Old Jul 25, 2004 | 06:58 PM
crj_lll's Avatar
According to JDM Honda parts it makes ten more. See the link below. That was what I was going by.
http://www.jhpusa.com/catalog/...3062a
Old Jul 25, 2004 | 07:33 PM
fast+forward's Avatar
higher compression helps a lil
Old Jul 25, 2004 | 07:39 PM
satan_srv's Avatar
http://www.jhpusa.com/catalog/...3062a</TD></TR></TABLE>
Your math skills aren't so good. Maybe you should check the link again.
USDM H22a = 158 ftlbs
JDM H22a = 161 ftlbs
Euro-R = 163ftlbs
5 more than USDM, 2 more than JDM. The main reason is higher compression
Old Jul 25, 2004 | 07:42 PM
Kal's Avatar
Kal
lol so funny.
Old Jul 25, 2004 | 09:15 PM
crj_lll's Avatar
My math skills are fine. Maybe you should check your reading skills and stop flamming people.
TYPE S
2.2 Liter DOHC VTEC Engine hydro operated tranny 220hp/<U>153tq</U>/11.0 Compression Ratio. Motor Swap incls LSD Tranny, ECU, axles with half shaft, stock shift linkage, stock motor mounts, alternator, starter, clutch, flywheel, intake manifold, exhaust manifold, fuel rail, injectors, distributor, engine harness. Motors average 15,000 miles and come with a 100% start up warranty.
EURO R
2.2 Liter DOHC VTEC Engine hydro operated tranny 220hp/<U>163tq</U>/11.0 Compression Ratio. Motor Swap incls LSD Tranny, ECU, axles with half shaft, stock shift linkage, stock motor mounts, alternator, starter, clutch, flywheel, intake manifold, exhaust manifold, fuel rail, injectors, distributor, engine harness. Motors average 15,000 miles and come with a 100% start up warranty.
163 - 153 = 10
Old Jul 25, 2004 | 10:04 PM
Spocko's Avatar
Wow if that is true, then you just REALLY made my day and reinforced that I made a good choice with the Euro-R over the Type-S. Cool, I love torque. i would trade 2 HP for every +1 torque if I could. HP is so easy to get compared to Tq
Old Jul 26, 2004 | 02:13 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">My math skills are fine. Maybe you should check your reading skills and stop flamming people.
TYPE S
EURO R
163 - 153 = 10</TD></TR></TABLE>
hahah that's a typo....type-s and euro-r are both 163, they are the same.
does it make much sense that a type-S would make 5 tq LESS than a USDM H22a?
you need better sources for information
Old Jul 26, 2004 | 03:01 AM
blackdelslo's Avatar
wow i learn something new everyday. I thought JDM H22A's made 155, Type-S and Euro-R both made 163
Old Jul 26, 2004 | 09:35 AM
sinjin22ap's Avatar
Default Re: H22 Euro r (delLudeVTEC)
satan_srv
I have a 92 Honda Prelude with a H22a and would like to get aprox. what you are making for power. Could you give me some insite on your build. Maybe a product list or somthing like that. My base line dyno run was 168 horse and 152 ft pounds.
Thanks
Old Jul 26, 2004 | 12:05 PM
crj_lll's Avatar
you need better sources for information</TD></TR></TABLE>
Well, that is why I camer here, to get more info on it, not to get flamed.
Old Jul 26, 2004 | 02:03 PM
satan_srv's Avatar
Well, that is why I camer here, to get more info on it, not to get flamed. </TD></TR></TABLE>
don't play innocent with me. you have a well documented history of some of creating some of the more annoying threads (also evidenced by your beauty title) that I really don't have much patience for your stuff. At least I answered it.
Old Jul 26, 2004 | 04:11 PM
musclefella's Avatar
don't play innocent with me. you have a well documented history of some of creating some of the more annoying threads (also evidenced by your beauty title) that I really don't have much patience for your stuff. At least I answered it.</TD></TR></TABLE>
WOW and Satan has spoken LOL
Old Jul 29, 2004 | 08:09 PM
crj_lll's Avatar
Then consider this your invitation to stay the F*** off of any thread I create. YOu have the rest of the websuite to flame. Go flex your muscle with them or if you want we can meet offline and setle this once and for all.
Old Jul 29, 2004 | 08:37 PM
satan_srv's Avatar
hahah ooooooh meet offline and settle this LOL
After 4 days, this is all you could come up with
-[Lucky]-
Sep 28, 2007 09:12 AM
97spooncivic
Dec 5, 2005 08:40 PM
trickeng
Oct 27, 2005 01:12 PM
codeh22a4
May 9, 2005 05:32 PM
jdmh22bubble
Jul 29, 2003 11:47 AM
