front tire cliking
Old Jul 24, 2004 | 05:52 PM
17GSR17's Avatar
Default front tire cliking
ok, as i drive i can hear my front driver side tire clicking. I changed the tires from front to back just to see if it was the lugnuts or some paper stuck but no my luck that wasnt it. It has not gotten any louder and it doesnt feel unsafe, can my axle be going out or is there a loose bearing or some crap like that. Cv boot looks fine also, any ideas people. thanks.
Old Jul 24, 2004 | 07:53 PM
Invisible01GSR's Avatar
Default Re: front tire cliking (17GSR17)
i had a clickling in the front and it was a bad wheel bearing
Old Jul 25, 2004 | 11:23 AM
{Mineral Grey} ITR's Avatar
Default Re: front tire cliking (Invisible01GSR)
check your wheel bearings........
Old Jul 25, 2004 | 11:49 AM
electronb16si's Avatar
Does the clicking get worse when you turn? If it does then axles might be your problem. If it doesn't then like the others said its most likely a wheel bearing.
Old Jul 25, 2004 | 12:57 PM
oldskool teggy's Avatar
Default Re: (electronb16si)
does it click when you turn? it could also just be the cv boots and axles
Old Jul 25, 2004 | 01:07 PM
Smeeg Heed's Avatar
When you rotated the tires, did it start clicking on the back? Very occasionally I will hit a big bump with my car and one of the front tires will hit the splash guard and a little string of rubber will get peeled off. It starts to make a ticking sound because the piece of rubber keeps hitting the inside of the splash guard.
Hopefully it's something like this and not something more serious.
Old Jul 25, 2004 | 02:53 PM
AzBlackTeg's Avatar
hummm? Mines the same I hear like a clicking sound coming from the passenger when I turn the wheel and its louder when I give the wheel all it has to the left and click..click..click. nothings touching. It just started a while back and now its getting louder and I barely turn the wheel it clicks. I had my axles replaced 6mths ago
Old Jul 26, 2004 | 06:41 PM
17GSR17's Avatar
Default Re: (AzBlackTeg)
thanks, by the sound of it, it should be a bearing. It has not gotten worse. It doesnt make any noise if i turn the wheel so hopefully that rules out axle. ill check bearings though thanks again.
Old Jul 28, 2004 | 08:12 AM
Default Re: (17GSR17)
good luck.. let us know what happens
Old Jul 28, 2004 | 08:14 AM
RidinStock's Avatar
Default Re: (Oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">does it click when you turn? it could also just be the cv boots and axles</TD></TR></TABLE>
Yea it wouldn't hurt to check the cv boot. Once dirt gets in there it can start clicking or making noise and stuff.
jdmrex90si
Dec 27, 2007 11:25 AM
jdmazm
Apr 28, 2005 07:57 PM
89JDMcrx
Apr 26, 2003 03:08 PM
Rain_man
Jun 21, 2001 10:21 PM
