Throw out bearing return spring?!?
Old Jul 24, 2004 | 05:39 PM
B-B-K's Avatar
Default Throw out bearing return spring?!?
Im running a S1 cable tranny with a Exedy stage one clutch. About 3-4 weeks ago I went to push the clutch pedal down to shift into 1st cuz the light turned green and when I pushed the pedal down I heard a loud snap. At first I thought it was my clutch cable. Replaced that, and wasnt the problem. Pulled the tranny found that the spring that returns the throw out bearin was broke. Went to Honda, got one for a 91 CRX si cuz I didnt know witch one to get. Maybe for a 90-93 teg? Anyways, it looked just like the broken spring. It was a tight fight but it worked.
Now the same thing happend, but the snap was as loud and I can still shift. I had to tighten the hell out of the clutch cable (Im running a teg cable, they are a bit longer then the CRX ones). But the throw out bearing isnt gettin fully trown back, its restin on the pressure plate.
Anyone ever had this happen? Or know why this is happening?
Thanks for any kids of help or input.
Matt
Old Jul 24, 2004 | 05:48 PM
DohcVtecCrx's Avatar
Default Re: Throw out bearing return spring?!? (B-B-K)
yes 90-03 teg one works perfect...about 4.56 at your local ACURA dealer or find it here: http://acuraautomotiveparts.org under the same teg then clutch release
Old Jul 24, 2004 | 08:19 PM
B-B-K's Avatar
Default Re: Throw out bearing return spring?!? (DohcVtecCrx)
Awsome, thanks man. Have you ever had a problem with this? Or ever heard of such thing happening?
Old Jul 24, 2004 | 08:20 PM
spaceman's Avatar
maybe you need to lube something..
Old Jul 24, 2004 | 09:14 PM
B-B-K's Avatar
Default Re: Throw out bearing return spring?!? (spaceman)
I usually do, I use white grease.
Old Jul 24, 2004 | 10:50 PM
SiR Kid's Avatar
New User
THe manual actually says to replace this any time there is a clutch replacement.... RTFM, already.
Old Jul 24, 2004 | 10:52 PM
ThatRicerDaniel's Avatar
I dont use any grease and have never had any problems .. i just use brake cleaner and a brush to always clean out the inside of the tranny.
Old Jul 24, 2004 | 11:11 PM
5litereater's Avatar
Default Re: Throw out bearing return spring?!? (ThatRicerDaniel)
i forgot to attach mine the firt time i put on my tranny and my clutch wouldnt engage at all...it doesnt make sense that you can get it into gear? anyways replace the bitch and get it goin again.
Old Jul 25, 2004 | 05:15 AM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-B-K &raquo;</TD></TR><TR><TD CLASS="quote">Awsome, thanks man. Have you ever had a problem with this? Or ever heard of such thing happening? </TD></TR></TABLE>
I had the same thing happen. When I disassembled, the spring was broken where it engages the throwout bearing. What happened (i think) was when I put it together, I got the fork on top of the spring instead of seated on the throwout bearing. It worked for a while until it broke the spring. Then, snap, lots of play in clutch and would not disengage. Pay close attention to where the fork is located.
HTH
chris
Old Jul 25, 2004 | 06:21 AM
spaceman's Avatar
Default Re: Throw out bearing return spring?!? (NCchris)
thanks for the info chris
Old Jul 25, 2004 | 05:09 PM
B-B-K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info chris</TD></TR></TABLE>
Good info. Im planning on gettin this done Tuesday. I work 5am to 1pm so Im going to be tired but I wanna get my car going again.
grampswrx
Jan 3, 2016 09:37 AM
DAcraze
Aug 18, 2009 03:50 PM
BoRiCuA
Sep 21, 2008 05:06 PM
iHOPEyouCHOKE
Nov 14, 2005 02:23 PM
jdm4drDA
Mar 12, 2003 03:51 AM
