Is it difficult to change wheel bearings???
Old Jul 24, 2004 | 05:26 PM
PAID-$$$'s Avatar
Default Is it difficult to change wheel bearings???
How hard is it to change a wheel bearing (rear) on a fifth gen. How much time should this take to do?? If anyone could provide some insight on this.... thanks..
Old Jul 24, 2004 | 05:51 PM
OTT's Avatar
OTT
Just support the vehicle properly
remove wheel
Remove brake caliper and rotor/hub (whicever is relevant to you)
Then remove hub cap, nut, washer and hub bearing assembly. Replace hub and bearing assembly as a unit.
Put it back to gether and torque it all to spec....
Brake line clamp bolts ......16ft/lbs = 22N.m
Splindle nut.......................136ft/lbs = 185N.m
Lug Nuts............................81ft/lbs = 110N.m
Brake Caliper mounting bolts....81ft/lbs = 110
Old Jul 24, 2004 | 11:37 PM
FIGARILA's Avatar
Default Re: (OTT)
I don't think you can just buy the bearing. You have to buy the hub with the bearing already pressed in (honda dealership). Assuming you did have a magical bearing, you would still need to get it pressed in and out.
Old Jul 25, 2004 | 10:23 PM
OTT's Avatar
OTT
No newbie he has stated this is a rear nuckle.
and FYI You can buy a set of wheel bearing for the front but you need the correct tools to press them in.
the hub bearing assemble bolts onto the nuckle at the rear
Old Jul 26, 2004 | 05:16 AM
Filthy Focker!'s Avatar
Default Re: (OTT)
BTW, if you don't have a press for the bearing, put the bearing in the freezer, and heat up your rotor. The bearing should just drop in.
fs
Old Jul 26, 2004 | 05:53 AM
rjr162's Avatar
Default Re: (filthy_shovel)
Autozone has the rear hub for around $60. Everywhere else I looked they wanted over $100.
As for the fronts, if you're in with your local shop well, they might do it for free. The honda dealership here did it for me (I wasn't swapping the bearing its self, but having it moved from one knuckle to another)
Old Jul 26, 2004 | 07:23 AM
PAID-$$$'s Avatar
Default Re: (rjr162)
So are u guys saying that its easier to change the rear bearing than changing the front one on a 5th gen??
Old Jul 26, 2004 | 07:44 AM
Daemione's Avatar
Default Re: (PAID-$$$)
Yes . . . . For the front you need a press. For the rear you don't.
So just get a new hub/bearing assembly, a new spindle nut & cap, and a helms. All the basic tools (socket set, torque wrench, etc), plus a big socket for the spindle nut & a good size breaker bar to get it off. Some kind of small punch or chisel to pry up the "staked" part of the spindle nut. Should be about it . . . .
Old Jul 26, 2004 | 08:27 AM
PAID-$$$'s Avatar
Default Re: (Daemione)
ok cool, thats what I was thinking too.....Just wanted to make sure that the back and front were different. Thanks a lot guys.
the learner
Jan 20, 2014 11:35 PM
Olaisen
Suspension & Brakes
Sep 3, 2010 07:20 PM
AlphaKennyWun
Mar 31, 2008 07:31 PM
ryanstev
Dec 30, 2007 01:31 AM
Shay91Racer
Apr 25, 2007 07:29 PM
