h22 timing and fuel pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13secondmonster »</TD></TR><TR><TD CLASS="quote">does anyone know wat the timing setting is on a h22a1 and wat is the fuel pressure supposed to be runnin at? holla at me asap</TD></TR></TABLE>
Timing 15+/- 2
Fuel pressure 28-32psi at idle with vaccum
Timing 15+/- 2
is that psi stoich. or a little lean ..... and timing do u set 15 degrees advanced or wat do u set it at? cuz im running a knock sensor code and its cuz the timinig is off and fuel mix is off
ITR.#1446
Mar 25, 2004 01:02 PM
nd8ch
Feb 26, 2003 06:40 PM
