1990 civic hatchback failed emissions test, its putting out too much NO2
Old Jul 24, 2004 | 04:13 PM
almies's Avatar
Default 1990 civic hatchback failed emissions test, its putting out too much NO2 what could be causing this?
No EGR valve, any ideas what could be causing this?
Modified by almies at 5:47 PM 7/24/2004
Old Jul 24, 2004 | 04:56 PM
90DX's Avatar
Default Re: 1990 civic hatchback failed emissions test, its putting out too much NO2 what could be causing t
I have the same prob. i am thining of replacing the cat.
But you should check timing also, (should be good)
Old Jul 24, 2004 | 05:01 PM
nomotor's Avatar
yeah me too! replace the cat and you should be all good.
Old Jul 24, 2004 | 05:06 PM
whitehf's Avatar
i had the same problem...but i have an egr..first i changed the cat...didnt reallie help....then he said my manifold was clogged up...changed that n it finnaly passed...
Old Jul 24, 2004 | 05:58 PM
almies's Avatar
"i had the same problem...but i have an egr..first i changed the cat...didnt reallie help....then he said my manifold was clogged up...changed that n it finnaly passed..."
DId you do it yourself? How much did it cost you?
Old Jul 24, 2004 | 10:33 PM
whitehf's Avatar
my bro replaced it for me...he had an old hf laying around n took out the manifold..cleaned it....made sure air flowed threw all the ports (with an air compresser)....slaped it on..whoopow..it worked...
joey7
19
Jan 29, 2013 10:54 AM
LAO
Jul 28, 2008 07:00 AM
bucdenny
22
Apr 28, 2005 11:11 PM
bucdenny
Apr 27, 2005 08:39 PM
SimbaDogg
Jul 2, 2003 09:17 AM
