thinner headgasket
Old Nov 26, 2001 | 12:57 PM
One8Hatch's Avatar
New User
Default thinner headgasket
who knows of a thinner head gasket for a B18b motor, that ups the compression somewhere around .4 points? any manufactures? and where could i get one? thanks
Old Nov 26, 2001 | 01:03 PM
Chris's Avatar
Default Re: thinner headgasket (One8Hatch)
If it fits the B18B...then:
Mugen.
METAL HEAD GASKET
A two-layer construction is used instead of the normal three-layer gasket plate construction, and a rib (+0.07mm) is laser-welded close to the plate surface sleeve to prevent blowout occurring at high compression. This head gasket raises the compression ratio by 0.4 points. Construction is entirely of stainless steel.
http://www.kingmotorsports.com/produ...ra/engine.html
Old Nov 26, 2001 | 01:38 PM
b18b98's Avatar
Default Re: thinner headgasket (Chris)
i heard if you get a 3 layer gasket..just take off the one of layers and that'll bump up compression..
Old Nov 26, 2001 | 04:58 PM
Project X's Avatar
Mugen doesn't make thin head gasket for the B18B.
Perhaps Mr. Gasket does, but I don't trust it.
Don't take 1 of the 3 layers of the stock Honda head gasket. There's a reason for having 3 layers.
Trying raising the compression by doing either of the following:
- high compression pistons
- deck the block
- mill the head
The 1st being the most preferred.
Old Nov 26, 2001 | 07:03 PM
gsr camel's Avatar
i am not sure but check a local parts store you would be surprised to see what they can get there hands on!
Twanks
[Modified by gsr camel, 11:04 PM 11/26/2001]
Old Nov 26, 2001 | 08:26 PM
Jesse H's Avatar
Default Re: thinner headgasket (gsr camel)
Adrian Teo from the hybrid forums is using 1 layer of the stock honda headgasket on his B18C1 with ITR head and valvetrain. From his writeup, it doesn't look like he did anything special, just made certain everything was withing specs and worked carefully.
Old Nov 26, 2001 | 09:57 PM
One8Hatch's Avatar
New User
Default Re: thinner headgasket (Project X)
- deck the block
- mill the head
yeah im putting in Pr3 pistons in and from what i read up on it should get me to 11.1.1 comp. im looking for around 11.5.1, and i didn't have enough to get some forged peices, and i dont think im going to mill the head or deck the block, it just doesnt sit right with me, so no one knows of a company that makes thinner headgaskets? i'll check out mr.headgasket. thanks
Old Nov 27, 2001 | 10:28 PM
One8Hatch's Avatar
New User
anyone know?
Old Nov 28, 2001 | 07:55 AM
arw321's Avatar
20 thou milling is perfectly safe!!
That's what I'm running.
Adam
NBP01LS
Sep 12, 2006 05:31 AM
Evs-One
Mar 3, 2003 01:09 AM
tek_civic
Nov 8, 2002 10:52 AM
Rhetoric
Jul 29, 2002 03:30 PM
B18CRacer
Jan 29, 2002 11:39 AM
