wireing in new deck. may of screwed up BIG!!!!!!!!!!!!
Old Jul 24, 2004 | 01:13 PM
themackingking's Avatar
Default wireing in new deck. may of screwed up BIG!!!!!!!!!!!!
hello. i was in the process of wiring in a new clarion deck inrelapce of the original honda deck. i am curently driving a 93 civic LX. as i was wiring in the new deck i accidently tounched a wire that had current to the ground wire causing it to short out. the wire that i shorted out was the only wire that had power when the deck was off. the wire is white with a blue strip on it. if any one can help me get power back to his wire it would be greatly appreciated.
thanks
Garrett
Old Jul 24, 2004 | 03:30 PM
Xsi's Avatar
Xsi
Sounds like you will have just blown a fuse, find your fuse box, change the fuse and you should be sweet.
Old Jul 24, 2004 | 06:40 PM
Auex's Avatar
Default Re: (Xsi)
That is the fuse labeled as backup or domelight. It may be under the hood.
Old Jul 24, 2004 | 07:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Auex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">That is the fuse labeled as backup or domelight. It may be under the hood.</TD></TR></TABLE> 7.5 amp in fusebox under hood 94
Old Jul 24, 2004 | 09:00 PM
skrewdriver88's Avatar
Default Re: (fcm)
thats why u should always disconnect the negative on battery before u start
Old Jul 25, 2004 | 06:47 AM
PSU's Avatar
PSU
formerly DxHatchback
Default Re: wireing in new deck. may of screwed up BIG!!!!!!!!!!!! (themackingking)
you guys sure its under the hood?
my dome light fuse is right beneath the steering wheel
Old Jul 25, 2004 | 07:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: wireing in new deck. may of screwed up BIG!!!!!!!!!!!! (DxHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">you guys sure its under the hood?
my dome light fuse is right beneath the steering wheel</TD></TR></TABLE> Yes its the constant power fuse under hood, did you check? it should be a 7.5 amp [ brown ] fuse, it is the one that powers the wire at the radio harness that is live even with ign. off.
If you have a high power HU you would be better off wireing the yellow power wire off your HU right to batt.
If it is the Clarion with two yellow wires [one thin and one thick] wire the thin one at the radio harness, and run the thick one to the batt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">thats why u should always disconnect the negative on battery before u start</TD></TR></TABLE> always
hope this helps. 94
I Love My 4 door
Dec 19, 2010 04:05 PM
lazyweasal4
Audio / Security / Video
Dec 12, 2006 04:06 PM
Crasian
10
Jun 9, 2005 09:06 AM
Double_Dk
13
Jun 27, 2003 06:24 PM
95gsr
Sep 18, 2001 09:25 AM
