Codes 3,21,22,23 are coming up. Check Engine HELP !!!!!!!!!!!
Old Jul 24, 2004 | 12:05 PM
eg6turb0's Avatar
Default Codes 3,21,22,23 are coming up. Check Engine HELP !!!!!!!!!!!
ok guys i really need ur help. when i first start the car up and drive it it runs really good. then after a little bit the check engine turns on. the car will idle at different speeds, it will bogg and sometimes die out, and the throttle response is bad. I checked the codes and they were: 3, 21, 22, and 23. if anyone could help me out here itd be sooo helpful.
code 3 is: map
code 21 : vtec spool selinoid
code 22 : vtec oil pressure switch
code 23 : knock sensor
by the way before my apexi vafc was installed the check engine didnt come on.
Old Jul 24, 2004 | 12:06 PM
dohcMONSTER's Avatar
Default Re: Codes 3,21,22,23 are coming up. Check Engine HELP !!!!!!!!!!! (klubhed1)
who installed your VAFC? did they do it blindfolded? thats prolly your problem
Old Jul 24, 2004 | 12:11 PM
B16_sol's Avatar
that happened to me, before my motor died
i was gettin tha same codes
Old Jul 24, 2004 | 12:17 PM
h23civic's Avatar
check your wiring for your ecu, i guarantee they messes up by either splicing some of the wrong wires or just leaving them open or cut. someone did this with my s-afc and i had to wire it back right.
paeaknoy
Sep 12, 2004 06:22 PM
94b18c1
Mar 23, 2004 05:35 PM
tegon-gsr
Jul 25, 2003 08:26 AM
topsekret
Dec 22, 2002 05:49 PM
