88 crx rear LCA's? what aftermarket ones will fit?
Old Jul 24, 2004 | 10:26 AM
ZC88CRX's Avatar
Default 88 crx rear LCA's? what aftermarket ones will fit?
What models will fit?
There is a local company selling megan racing ones for cheap and i wanna pick a set up for when i put in the new suspension setup.
btw - its for an 88 crx dx.
thanks.
Old Jul 24, 2004 | 10:49 AM
91EFHatch's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (ZC88CRX)
i know the SRR LCAs fit in the ef hatch (LCA for the EG) so they should fit or ur rex.i m getting the srrs for 185 never heard or megan? prob cheap crap
Old Jul 24, 2004 | 10:53 AM
crxgator's Avatar
megan sucks...
function7 makes them for the 88 crx/civic...i personally got brand new honda lcas...
Old Jul 24, 2004 | 12:38 PM
spaceman's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (crxgator)
does function7 have a website?
Old Jul 24, 2004 | 12:53 PM
crxgator's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (spaceman)
i think its http://hybridgarage.com are the ones who make it...i forget...
Old Jul 24, 2004 | 01:00 PM
91EFHatch's Avatar
those look like **** to me
Old Jul 24, 2004 | 01:10 PM
JapJunkie's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (91EFHatch)
SRR LCAs
Old Jul 24, 2004 | 01:24 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EFHatch &raquo;</TD></TR><TR><TD CLASS="quote">those look like **** to me </TD></TR></TABLE>
and looks have what to do with function...
Old Jul 24, 2004 | 06:49 PM
91EFHatch's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (hOnDadiCt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOnDadiCt &raquo;</TD></TR><TR><TD CLASS="quote">SRR LCAs </TD></TR></TABLE>
Old Jul 24, 2004 | 06:55 PM
spaceman's Avatar
does srr have a website?
Old Jul 24, 2004 | 10:05 PM
krazie1's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
and looks have what to do with function... </TD></TR></TABLE>
very correct my friend
no one will even see them and unless u road race the car u won't feel a difference
Old Jul 25, 2004 | 08:21 PM
ZC88CRX's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (krazie1)
in case anyone else cares to know..........
https://honda-tech.com/zerothread?id=930352
Old Jul 25, 2004 | 09:25 PM
racerxb18b's Avatar
srr's are nice but its too bad they don't make them for an 88.
as almost always the answer is at your local honda/acura dealership
TYPE-R lca's all the way
Old Aug 4, 2004 | 10:44 AM
Full Race A6's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (racerxb18b)
bump, I need something for an 88 crx. My rear lca bolts are ******* seized so I need some new ones, dont care if there used or what, as long as they bolt up using the 88 style shocks and come with bolts/bushings
Old Aug 4, 2004 | 01:27 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (Full Race A6)
DA rear assembly
Old Aug 4, 2004 | 01:34 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (Jurassic Four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">DA rear assembly </TD></TR></TABLE>
Wrong shock mount.
Old Dec 31, 2004 | 06:52 AM
FrankencrxBHAM's Avatar
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (4drEF)
still what ones are for the 88.
Old Dec 31, 2004 | 10:14 AM
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (FrankencrxBHAM)
i need the website for megan racing, ssr, and also onmipower now carries them but i dont know if its for the 88.
Old Dec 31, 2004 | 03:52 PM
Kwicko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">still what ones are for the 88. </TD></TR></TABLE>
It's already been answered: The Integra Type R rear LCAs are the same as the '88 CRX. They're designed with a little bit of toe-correction built into them (they flex just a bit under load, and I believe the outside wheel in a turn toes out a bit), so they help the car rotate. American drivers had problems with this in some situations, because off-throttle oversteer became an issue with these cars for some stupid people. The US got the redesigned rear suspension for '89 and after, while the rest of the world got better-handling CRXs.
I miss my '88 Si...
Mike
Old Dec 31, 2004 | 03:58 PM
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (Kwicko)
ok wow, you people arent getting it, then who makes and after market one for the type r, cause im not paying the money for true type r ****. also would they fit without having to change ANYTHING.
Old Dec 31, 2004 | 06:29 PM
EL Vap133's Avatar
Or you can get the 89-91 style aftermarket LCAs and 89-91 style struts.
Old Jan 1, 2005 | 12:59 PM
Default Re: 88 crx rear LCA's? what aftermarket ones will fit? (EL Vap133)
thank you, finally something helpful.
ThatOneOG
Mar 1, 2008 08:31 PM
dxcivic
Jun 5, 2006 04:46 AM
ecsahs3
Jul 7, 2004 10:59 PM
mr. Grind
Jun 30, 2004 12:08 PM
elmalouno
May 10, 2003 07:15 PM
