Smog failed Please help!
Old Jul 24, 2004 | 09:56 AM
88hondaccord's Avatar
Default Smog failed Please help!
I didn't pass smog on this car i have if anyone can tell me anything about it please help i need to get the tags by the 8th the people wanted $175 to find out what it is i think its the CAT if anyone can help that would be great
thanks
1988 accord lx 2.0 ltr 2b carb
Everything but the 15 mph <U>NO (PPM)</U> passed
Good old CA
Modified by 88hondaccord at 11:19 AM 7/24/2004
Old Jul 24, 2004 | 07:33 PM
IanCT's Avatar
Default Re: Smog failed Please help! (88hondaccord)
High NOx readings are sometimes attributed to a bad EGR valve, or component (blocked vacuum, hose, etc) relating to the EGR system.
How is the fuel pump? A lean air/fuel mixture can be caused by low pump pressure, causing high block temps. That can cause excessive NOx emissions as well.
Or as you suggest, clogged cat can be the problem as well.
Old Jul 24, 2004 | 10:19 PM
Schmitey's Avatar
Default Re: Smog failed Please help! (IanCT)
I don't know **** about carburated but definitely check your EGR/vacuum lines. Clogged cat would smell like sulfur (wrotten eggs) and one would assume they would have said something.
Might try this to clean stuff up...
https://honda-tech.com/zerothread?id=902955
Old Jul 25, 2004 | 08:01 AM
Default Re: Smog failed Please help! (Schmitey)
Yea they said that it would cost them $175.00 to find out and thats a bunch of BS i know about cars i just dont know about these cars but yea anymore info from anyone would help. looks like the egr so far.....
Old Jul 25, 2004 | 08:45 AM
Chiovnidca's Avatar
Have you checked your ignitioon timing? Retarding it a couple degrees from stock will probably get you a pass.
Old Jul 25, 2004 | 09:48 AM
92lsr's Avatar
Default Re: Smog failed Please help! (Chiovnidca)
yeah a few degrees back and some carb cleaner and some guarented to pass smog should get you to pass
Nicks95GSR
May 21, 2008 07:37 AM
Ritchie
24
Jul 1, 2007 07:30 PM
SiRII_Izzy
21
Aug 24, 2004 07:06 PM
Go Mifune
Jan 7, 2002 03:06 PM
Go Mifune
Nov 19, 2001 11:52 AM
