Ingalls camber kit (anchor bolt for front)?
does ingalls not make an anchor bolt application for the front for a 5th gen? I can't find them, someone told me they only make ball joints for the front.
does anyone know of a company that makes anchor bolt type for the front?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm »</TD></TR><TR><TD CLASS="quote">are they any good? any probs with clearance issues?</TD></TR></TABLE>
dont know, mine are on order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny »</TD></TR><TR><TD CLASS="quote">I had just recently put the Ingall front camber kit on my 5th gen and I have had no problems or clearence issues. Ball joint kit by the way.</TD></TR></TABLE>
what part number did you get and what's your drop in inches?
i figured out why anchor bolts won't work in the front today. Took off my wheel and it was clear as day. The mounts on the upper control arm are fixed to welds on the body and aren't mounted in the same fashion as the rear through the wheel well, so ball joint is the only way for the front
raidacaipo
13
Oct 14, 2009 10:05 PM
