GSR-Type R
I was wondering, since i can't afford a real type-R engine, if i take a GSR block, rebuild it to the Type-R specs, aka C/R, and use a type-R head, would i be able to use a type R ecu and or the JRSC for the type R? any help is thanked
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
GSRs aren't slow, I have seen some Type Rs at the track in stock configuration running low 15s. I run 15.1s COMPLETELY stock. Just get the JRSC for the GSR. Why even bother building a motor to Type R specs, that doesn't make sense like the Chewbacca defense.
that would be a waste... mayb there is a point of a swap to a jdm type r engine but then built it how u can not goin to jdm specs... other then that it is just a waste GS-Rs can built to a very strong car!
Like stated in nearly every comment. Build the GSR.
First off, you can build up your bottom end to handle some big cams, get yourself a valvetrain, headwork, good header back setup, tranny work-possibly a final drive, cams, engine management and a tuner. With that you could push 200whp all motor and be happy as hell. Plus you would destroy a type R with that type of buildup.
the type-r is only like .2:1 higher in crompression, why would the gsr be a better platform then type-r for boost? if you lower the compression in the type-r, couldn't you be able to boost it more then if you had the same low compression pistons in the gsr?
the reason i was asking is i can to do a stroker kit in a gsr block. I can choose my C/R and i thought since JRSC makes a kit for the Type-R why not take the Type-R C/R and use that kit, thus more power with the S/C
There is no reason for that swap. Jackson Racing makes a supercharger for the GS-R. Why would you want to have higher compression and boost? That's makes no sense. Lower compression with boost I understand. You can pretty much pick your boost, as long as you get the right pulley. There is a limit because of the blowers design.
