im going to vent... then im going to build the hell out of it!!!
Old Jul 24, 2004 | 02:07 AM
LSTEG96's Avatar
Default im going to vent... then im going to build the hell out of it!!!
ok so... my lsvtec has no compression... kinda thought that (burned oil and what not)... 145 psi ACROSS THE BOARD in a motor that should have 11.6:1
added oil to the cylinder... the word **** was said many times at it tapped out the 290 psi gauge.
now... i thought a heat shield was loose... it rattled..then tonight, going down the freeway, i thought it fell off! which made me jack it up and take a look....
anyone wanna guess what the noise was? as i changed lanes in 5th, at about 4000rpm, i put her to the floor... and thats when i heard the noise...which i thought was the heat shield...
HOLY **** was i wrong. theres a hole the size of my fist in the ******* tranny. my fist people... not all the way to the case, just the motor mount on the back... there was still a PIECE of the bolt sitting up there... WTF.
im pissed, im going to bed, im going to rebuild the **** out her.
Old Jul 24, 2004 | 02:50 AM
DC2*Integra's Avatar
Default Re: im going to vent... then im going to build the hell out of it!!! (LSTEG96)
that sucks. hopefully ur rebuild will go well
Old Jul 24, 2004 | 04:06 AM
-faded-'s Avatar
Default Re: im going to vent... then im going to build the hell out of it!!! (DC2*Integra)
good luck with the rebuild. some things happen for a reason
Old Jul 24, 2004 | 05:49 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
what doesn't kill you only makes you stronger. good luck, i know you'll learn quite a bit from this.
Old Jul 24, 2004 | 09:27 AM
Dogginator's Avatar
Daisy... Daisy...
How much oil did you add to the cylinders?
The tranny is unfortunate. Good luck with the rebuild.
Old Jul 24, 2004 | 10:15 AM
LSTEG96's Avatar
Default Re: im going to vent... then im going to build the hell out of it!!! (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">How much oil did you add to the cylinders?
The tranny is unfortunate. Good luck with the rebuild.</TD></TR></TABLE>
not too much, just enough to coat the walls i guess?
Old Jul 24, 2004 | 02:08 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
not too much, just enough to coat the walls i guess?</TD></TR></TABLE>
I'm just surprised by the huge increase in compression from the oil addition.
Old Jul 24, 2004 | 03:50 PM
K.F14's Avatar
At least your attitude is positive Make her stronger
Old Jul 24, 2004 | 03:54 PM
No-Gi's Avatar
He added oil down the sparkplug hole, not the valvecover.
Old Jul 24, 2004 | 05:18 PM
LSTEG96's Avatar
Default Re: im going to vent... then im going to build the hell out of it!!! (3_South)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3_South &raquo;</TD></TR><TR><TD CLASS="quote">He added oil down the sparkplug hole, not the valvecover.</TD></TR></TABLE>
yep.. and then my comp went up so the rings are bad correct? god damn they are all gone nice and evenly... 145psi ACROSS the board...well i guess i got 160 WOT.
Old Jul 24, 2004 | 06:34 PM
Dogginator's Avatar
Daisy... Daisy...
A-hem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">How much oil did you add to the cylinders?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">yep.. and then my comp went up so the rings are bad correct? god damn they are all gone nice and evenly... 145psi ACROSS the board...well i guess i got 160 WOT.</TD></TR></TABLE>
Yes, the increase should indicate that the rings are bad. You usually add just a few dops of oil to the cylinder. Otherwise, the oil will reduce the combustion chamber volume and raise the perceived compression. I think that exceeding the gauge limit seems a bit excessive.
92 EGferio
Feb 9, 2012 12:42 PM
crxalx
Sep 16, 2011 12:00 AM
