what does this mean?
Old Nov 26, 2001 | 11:25 AM
Veil_Side_'s Avatar
Default what does this mean?
1. Port and polished?
Old Nov 26, 2001 | 03:58 PM
fsarfino's Avatar
Default Re: what does this mean? (Veil_Side_)
ports on the cylinder head are enlarged and polished for more air flow this is mesured in CFM
Old Nov 27, 2001 | 02:49 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: what does this mean? (dohcvtec16)
but if you POLISH the ports, you kill air flow. Only go as high as 120 grit on the flapper wheel.
Old Nov 27, 2001 | 02:58 AM
MiraiZ's Avatar
Default Re: what does this mean? (Mista Bone)
polished ports = improved flow...!!!
Old Nov 27, 2001 | 03:31 AM
Max GSR's Avatar
Default Re: what does this mean? (MiraiZ)
Polished smooth does NOT mean improved flow. I could give you some analogies involving water along the edge of a stream versus the water in the center of the stream being totally unaffected, but I won't. The porting is the most influential aspect of P&P because it's the shaping of the chambers that determines air velicity through those chambers which determines power.
Old Dec 3, 2001 | 07:53 PM
Todatyper's Avatar
Default Re: what does this mean? (Max GSR)
You should only do a mild port/polish job, doing too much can hurt the car.
beasty=eg
Oct 1, 2008 06:52 PM
tommy b
Aug 14, 2003 09:13 AM
Full-Race Geoff
Jan 16, 2003 09:52 AM
earl
Nov 28, 2002 07:47 PM
paulzy
Aug 2, 2001 11:10 AM
