OBD2 converted to OBD1...Do I still need both O2 sensors?
Old Jul 23, 2004 | 10:16 PM
rhettster's Avatar
Default OBD2 converted to OBD1...Do I still need both O2 sensors?
Like it says, I'm running a P28 ecu with a Hondata s200 on a 99 Si (going turbo).
I've got one O2 sensor in the cat, and another one that's hanging unless I get the fitting welded to the downpipe. I found one post in the archives that says that OBD1 cars only have one O2 sensor. So can I forget the one that comes before the cat?
Thanks in advance
Old Jul 24, 2004 | 07:08 AM
SOHC_MShue's Avatar
Default Re: OBD2 converted to OBD1...Do I still need both O2 sensors? (rhettster)
make sure you get that hanging o2 sensor back into your downpipe. You don't need the one in the cat, but I would just leave it in there unless you wanna plug up the hole where it was.
Old Jul 24, 2004 | 08:56 AM
hulkhb's Avatar
Default Re: OBD2 converted to OBD1...Do I still need both O2 sensors? (SOHC_MShue)
take is out so it isn't being wasted. go to the hardware store and get a M18X1.50 hex head bolt and slap it in there.
Old Jul 24, 2004 | 09:50 AM
Griffin@Camtech's Avatar
No you wont need it as above just get a plug and cap it off
Old Jul 24, 2004 | 08:33 PM
rhettster's Avatar
Default Re: OBD2 converted to OBD1...Do I still need both O2 sensors? (Stickdeath)
Ok, so the one in the cat is uselss, but I need the one forward of that? Sorry to beat a dead horse...just want to make sure I do this right.
Old Jul 24, 2004 | 08:34 PM
hulkhb's Avatar
correct keep the primary (first one) in.
Old Jul 24, 2004 | 09:07 PM
rhettster's Avatar
Default Re: OBD2 converted to OBD1...Do I still need both O2 sensors? (hulkhb)
Cool. Thanks for the good info, guys!
strongarm1731
Feb 26, 2006 12:25 PM
smkngsr
Apr 6, 2005 01:58 PM
jentegraGS-R
Apr 2, 2004 02:40 AM
964dgsr
Sep 25, 2003 07:53 AM
hotboi850
Aug 18, 2003 08:46 PM
