squeeking brakes need help asap
Old Jul 23, 2004 | 08:54 PM
afhockeyfreak4ml's Avatar
Default squeeking brakes need help asap
ok well i got some spueeky brakes and i dont know what the problem is i have already changed the brake pads and it's the front brakes need help
Old Jul 23, 2004 | 09:23 PM
tommymoose's Avatar
Default Re: squeeking brakes need help asap (afhockeyfreak4ml)
What kind of brake pads? The quality of the pad could have something to do with it. When you were replacing the pad did you see any damage or scratches on the rotor from using the old pads for too long? It also could help to quickly go over the rotor with emory cloth or sandpaper to get off any glaze that is on there.
Old Jul 23, 2004 | 11:24 PM
Default Re: squeeking brakes need help asap (tommymoose)
so take some sand paper and go around the rotor. or use a cloth i mean it's really loud and ear pearcing but i know it's not the pads i used becasue i used the same kind for my prelude and there fine and they dont squeek do you hand anyother ideas??
Old Jul 24, 2004 | 07:01 AM
EnjoyTheRideDC2's Avatar
Possibly your calipers need to be re-greased or rebuilt. Run to a parts store, grab some brake assembly lube. Apply grease to the caliper pin and boot. Might do the trick.
Old Jul 24, 2004 | 05:01 PM
Default Re: squeeking brakes need help asap (EnjoyTheRideDC2)
do you have a pick of what i need to put it on or can you just tell me where i need to ?? thanks your a big help
Wilky
Jun 6, 2007 01:35 PM
Babakarab
May 12, 2007 10:12 AM
realis9
Feb 16, 2006 05:41 PM
Poopie
Jun 25, 2004 07:03 PM
BlownVR
13
May 17, 2004 01:05 PM
