detonation
Old Nov 26, 2001 | 10:04 AM
initial-d's Avatar
Default detonation
What causes detonation? I'm afraid that with my new cams I might hear detonation. How do I avoid it?
Old Nov 26, 2001 | 10:23 AM
CivicV10@18000rpm's Avatar
Default Re: detonation (initial-d)
Need more info.
Old Nov 26, 2001 | 11:16 AM
BoM's Avatar
BoM
Default Re: detonation (CivicV10@18000rpm)
u've been posting about pinging and detonation lately...
can u pull the spark plugs for us and take a picture....
Old Nov 26, 2001 | 12:46 PM
sol-man's Avatar
I heard that gas with low octane will casue detonation but Im not sure.
Old Nov 26, 2001 | 12:55 PM
One8Hatch's Avatar
New User
isn't detionation when the tempatures in your cylinder get too hot, and your gas ignites before its supposed to? you can avoid it by using higher octaine if your not pinging real bad, i think you can also retard your ignition timming too. good luck
Old Nov 26, 2001 | 01:37 PM
BoM's Avatar
BoM
Default Re: detonation (One8Hatch)
use super...or ultra sunoco gas....retard your timing.
Old Nov 26, 2001 | 06:10 PM
Max GSR's Avatar
You kids should learn how to use the Internet better!
The Mystery of Detonation
How to cure Engine Knock
Old Max
Old Nov 26, 2001 | 07:52 PM
rainforest's Avatar
Default Re: detonation (Max GSR)
excesive compression
lean fuel
ridicuouslly advaced ignition timing
a lot of little things.
some ways to stop detonation is keep the motor cool, By water cooler radiator thermostat. have enough spark.
young_tuner
Oct 26, 2008 03:36 PM
hondasport2000
May 17, 2004 01:29 PM
_Endless_
Feb 21, 2003 01:49 AM
mr_mbuna
Nov 28, 2002 11:12 AM
RTW DC2R
Nov 12, 2002 03:04 PM
