D15b2 block+A6 head
d15b2 block, d16a6 head/intake manifold/dizzy/ecu
swapped to MPFI with I/H/E.
good zippy start for a turbo project later on? i've been told it will put out ~120horses and good for low 15's high 14's with an SI tranny and good driver.
opinions?
--gabriel
opinions?
--gabriel
The A6 head is the same as the head you have on now.
The cam is different and that's about it.
Change out the cam and save yourself from spending the $ and time swapping heads and headgaskets.
Other than that, it should be a decent little motor to drive hard and blow up!
so the cam is the only difference in the heads? if that's the case i'll swap the cam and build the other head up before building up the block for boost.
and i won't blow it up.
--gabriel
--gabriel
rice is nice
May 21, 2005 11:52 AM
blackeg
Dec 30, 2003 11:00 AM
Rob Dizzle
Dec 8, 2003 06:04 PM
