gsr head over b16 head?
Old Jul 23, 2004 | 02:16 PM
EFin' Kyle's Avatar
Default gsr head over b16 head?
what would a gsr head give my that a b16 head wouldnt on a b16 block? better combustion? more horses?
Old Jul 23, 2004 | 08:57 PM
EFin' Kyle's Avatar
Default Re: gsr head over b16 head? (crxstreetracer90)
bump
Old Jul 23, 2004 | 10:26 PM
90dxhatch's Avatar
i dont think it would do you any good, all a type-r head is a port and polished b16 head. nut i could be wrong.
-joe
Old Jul 24, 2004 | 01:36 AM
Malgerus's Avatar
.2 more compression. You can easily mill a B16A head to achieve that.
Old Jul 25, 2004 | 09:35 PM
GWInquisitor14's Avatar
Default Re: gsr head over b16 head? (Mr. S)
If you wanna turbo, B16 is the way to go
Old Jul 26, 2004 | 11:41 AM
notstock93's Avatar
Default Re: gsr head over b16 head? (GWInquisitor14)
GSR head will give you .2 higher CR, better quench pads and better flow at high lift (alaniz graph)
Also, it allows you to use the GSR dual stage runner to get more midrange out of the b16. I have the setup, it works well.
Old Jul 26, 2004 | 08:57 PM
EFin' Kyle's Avatar
Default Re: gsr head over b16 head? (notstock93)
notstock93 do u have any tips fot this motor bcuz i am building it up myself and need tips if u have any. tahnx
-Kyle
Old Jul 26, 2004 | 09:40 PM
hybrid89's Avatar
stock for stock, the GSR head flows a little better, but it has the bastard intake bolt pattern. GSr has higher compression. don't use the GSR manifold. get a replacement like a S2, or type -r. Edelbrock if you plan to go FI.
matt
Old Jul 26, 2004 | 10:09 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxstreetracer90 &raquo;</TD></TR><TR><TD CLASS="quote">notstock93 do u have any tips fot this motor bcuz i am building it up myself and need tips if u have any. tahnx
-Kyle</TD></TR></TABLE>
If you dont want to use the GSR manifold, then dont bother getting the harder to find and more expensive P72 ECU. If you do want to use it, start looking now. If you have the motor apart, use this time to get some ARP rod bolts for cheap insurance on the bottom end. If you have the money, get the type-r valve springs NOW, so when the time comes, you can upgrade to ITR cams without any sort of valvetrain upgrade. Other than that, just make sure that you have some sort of fuel/ignition tuning device to fine tune any bugs out of the system if your using the P72 ECU. It was set-up to run at 10:1 (USDM) and suddenly it has .4 more CR to deal with, it may make for awkward power delivery. Detonation should NOT be a problem on 91+ octane.
Drew17th
Oct 11, 2006 10:18 AM
90teg
Jul 2, 2005 11:22 PM
maxheat
24
Feb 26, 2005 12:36 PM
maziospzza
Dec 2, 2004 12:33 AM
OreoEF8
27
Aug 20, 2004 10:16 PM
