rear camber kit=washers
Old Nov 26, 2001 | 09:21 AM
internet ay's Avatar
Default rear camber kit=washers
someone told me to correct the camber in the back of a crx you can use washers on that arm on the top of the suspension between the arm and the body does this work?? has anyone done it.
Old Nov 26, 2001 | 09:37 AM
rioninja's Avatar
Default Re: rear camber kit=washers (internet ay)
I have done it and it works fine. Just MAKE SURE to use longer bolts to make up the difference. It will only take about 3 or so washers to correct for a 2" drop. All depends on thickness of washers or course. Good luck
Old Nov 26, 2001 | 09:38 AM
rioninja's Avatar
And hey, where are you in Yardly? I live in Philly and work in Penndel.
Old Nov 26, 2001 | 06:35 PM
Default Re: rear camber kit=washers (RioNinja)
i live like 10 minutes from pendel i live 5 minutes from the oxford valley mall what does your car look like is it white??
Old Nov 26, 2001 | 08:54 PM
rioninja's Avatar
yeah, with the F'in disgusting stripe on it. I think i may have met you before while i was with my friend JD.
Old Nov 26, 2001 | 09:27 PM
yo i thought that that was you you have the gsx-r muffler right i met you at that burger king on oxford valley road with tj sczcur. i wanted to race you remember. i was the tall kid. i see your car in pendel on the occasion off of business route 1 in a parking lot.how is the car running , you had the 2nd gen jdm b16 right? what did you run?? so back to the topic, where did you find longer bolts just at a hardware store??
Old Nov 27, 2001 | 05:07 AM
rioninja's Avatar
Yeah, thats me. I work at the phone store across the street from where i park my car. And yeah, just hit up pepboys or something to find a bolt.
I never got a chance to run my car yet, but i have my new clutch in so whenever your ready to line it up let me know
[Modified by RioNinja, 9:08 AM 11/27/2001]
Old Nov 27, 2001 | 09:16 AM
i would race you but i had a bit of transmission failure. my y1's differential decided to shatter into many peices and poke holes all over my diff housing and leak trans oil all over my act clutch . so i pulled the motor and i am not putting it back in until it is turboed. so we will race then. thanks for the info in the bolt.
Old Nov 27, 2001 | 10:47 AM
rioninja's Avatar
That is cool. Hey, do you need any LS parts? Let me know, i got a bunch of **** laying around.
properlystewed
Suspension & Brakes
20
Jun 19, 2014 06:47 PM
Blacksole
Honda S2000
Nov 9, 2011 06:58 AM
RATEDR
Acura TSX
Sep 22, 2008 09:53 PM
cbmprelude
Apr 11, 2005 01:58 AM
singlecam screamer
Jan 9, 2003 08:26 PM
