Spun a bearing
Old Jul 23, 2004 | 01:38 PM
marky01lsteg's Avatar
Default Spun a bearing
well today i went to acura and got a diagonosis on my ls teg and after 4 hrs of tear down time and $380 broke and most importantly, impatiently waiting, they said i spun a bearing in my crankshaft and i've only have had the car for about 4 months now and the car is still completly stock and have gotton regular maintence checkups and i was just wondering how could i spun a bearing on the crankshaft if its all stock and only had it for 4 months, what could be some possibilities of why this would have happen?
2001 LS
All Stock for now
Old Jul 23, 2004 | 01:50 PM
electronb16si's Avatar
Lack of lubrication.
Old Jul 23, 2004 | 02:40 PM
Curtisbeef's Avatar
Default Re: (electronb16si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electronb16si &raquo;</TD></TR><TR><TD CLASS="quote">Lack of lubrication.</TD></TR></TABLE>
Correct this happened to my friend about a month ago
was getting on it and had no oil in the car
Old Jul 23, 2004 | 02:47 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Curtisbeef)
That's pretty much the only way you can spin a bearing.
Lack of lubrication. Did you run the car a while without an oil change or without oil?
The other way it could happen is if you installed the bearing wrong, but that would cause it to "spin" pretty quick, as in as soon as you started the motor....or at least very soon after that.
Old Jul 23, 2004 | 07:23 PM
Default Re: (shamoo)
well yea i was thinking the same thing when i thought i didnt have oil in it but the dipstick read full, and it wasnt leaking oil nor burning, and i think i was maybe a 1,000 miles over as far as my oil change. Do you guys think that the oil pump could have went out because that could be a possibilty? And Acura are suchs dicks because they are trying to find all the reasons in the world of not paying for the estimate which ran to a ballpark range of 2400 to fix it but thanls goodness for WARRANTYS
Old Jul 23, 2004 | 07:35 PM
gsrboi80's Avatar
Default Re: (marky01lsteg)
make sure they fix that **** man. Dont let them try and bs you like it was your fault or somthing
Old Jul 23, 2004 | 07:45 PM
Curtisbeef's Avatar
if your oil pump was messed up you would have ALOT of problems
Old Jul 23, 2004 | 07:47 PM
Default Re: (gsrboi80)
yea they have been trying to bs me all day long but finally they gave me a rental for the weekend and then there gonna have a adjustor come out and look at it because of the large sum of money/repairs they have to do and they also wanted me to pay for the tear down fee in which that determined wat was really wrong in it. i dont have any performance parts on it and the problem is in the internals in which they cover under warranty, and do you guys think it could be any way they could get out of paying for my repairs on my car and could they find evidence that i didnt get a oil change in 1000 miles because everything looks good except for that bearing being spun
Old Jul 23, 2004 | 07:50 PM
well i dont know if my oil pump is messed up, it was just a possibility or could that even be possible and if the oil pump was messed up, what would be some problems/failures that it may lead to?
Old Jul 23, 2004 | 08:03 PM
Curtisbeef's Avatar
well if it breaks into peices then your gonna have metal shavings in just about every part of your engine... that is bad
i dont think you would be able to drive it at all with that broken
Old Jul 23, 2004 | 08:07 PM
curtisbeef your talking about my bearing being all over the engine right???? and as far as them fixing my car what will be done to the crank or whatever for them to correct my car and have it running great again and how long does it usually takes for them to fix it, but hey they are paying for all the charges on the rental car
Old Jul 23, 2004 | 08:10 PM
Curtisbeef's Avatar
No i was talking about if you oil pump breaks...
If you spun a bearing the should micro polish the Crank and put new bearings in and fix any other damage it may have caused
Old Jul 23, 2004 | 08:18 PM
oh ok. well whenever i checked the oil yesterday on the dipstick there were little specks on it as if the bearing or something was in the oil system with tiny little objects
Old Jul 23, 2004 | 08:20 PM
Curtisbeef's Avatar
that happens with with spun bearings my friend spun his bearing and we took of the oil pan and it looked like someone poured glitter in it bad things
Old Jul 23, 2004 | 08:27 PM
yea thats exactly how it looks, well i hope acura resolves this problems within a couple days or so and not be dicks because they wanna see all of my receipts to when i got all my oil changes or any info to me getting my regular scheduled maintence checkups
Old Jul 23, 2004 | 08:29 PM
Curtisbeef's Avatar
good luck with all that stuff hope it works out
Dat1BVtecN
Feb 1, 2007 07:33 PM
black7hatch
Dec 3, 2006 03:47 PM
T-King
Jun 3, 2005 11:19 AM
rasinhell
12
Jan 14, 2005 06:46 PM
petrv
Aug 10, 2004 08:52 PM
