Crackling noise from speakers
Old Jul 23, 2004 | 01:05 PM
RidinStock's Avatar
Default Crackling noise from speakers
Hey Everyone,
I have two amps wired up, one 4-channel hooked to four polk audio db650's, and one 4-channel bridged to two 12" subs. The power wire comes from the engine, through a hole in the firewall, and along the bottom of the door (ripped up the carpet) to the back. The head unit is still stock, connects to a speaker level to RCA converter, and the two channels follow the same route to the back. The two front speakers run along this same channel.
Here's my question, when I turn my music up high and it has higher tones in it (such as Linkin Park vs. 50 Cent) it starts to crackle and sound really bad. Is this because the power wire is close to the speaker wire? I never had a real bad problem until today. Sorry for the long post, just tryin to give you some kind of background. TIA.
Old Jul 24, 2004 | 09:14 AM
RidinStock's Avatar
Default Re: Crackling noise from speakers (RidinStock)
Bump.
Old Jul 24, 2004 | 01:30 PM
CYM19z's Avatar
you should never run both on tha same side.. RCA on one side - Power on tha other...
what is crakeling? tha speakers or subs what... does it sound like tha speakers are blown or - maybe over powered... could be soemthing is grounding out...??...
Old Jul 25, 2004 | 01:26 PM
RidinStock's Avatar
Default Re: Crackling noise from speakers (CYM19z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CYM19z &raquo;</TD></TR><TR><TD CLASS="quote">you should never run both on tha same side.. RCA on one side - Power on tha other... </TD></TR></TABLE>
This might be the problem, I had someone helping me because this was my first install, so that's the way he ran the wires. The 6 1/2's are crackling, sometimes in the front, sometimes in the rear. I'm starting to think its faulty wiring cuz the front just started cuttin out. I think its time to buy a new head unit and get rid of the stock one. Thanks though.
Old Jul 25, 2004 | 05:10 PM
debogsr's Avatar
check your cd's. For the longest time i thought my speakers were messed up, and it was that my burner wasnt burning right. Just a thought although it probably wont solve ur prob
Old Jul 25, 2004 | 10:04 PM
RidinStock's Avatar
Default Re: Crackling noise from speakers (debogsr)
Still good lookin out though, I'll look into that too. Thanks.
MyDad'sCivic
Audio / Security / Video
Jun 28, 2014 10:42 AM
98civdx
Jan 3, 2012 09:12 PM
abusedvtec
May 4, 2008 09:56 AM
ITR640
Oct 25, 2007 10:04 AM
dtran002
Nov 16, 2005 01:34 AM
