swap
Old Jul 23, 2004 | 11:36 AM
EF9 JAMS!!!'s Avatar
Default swap
which is easiest to do?? a std swap, with a b16 or a si ??? probably the si i suppose. i'm pretty sure the si would be easiest and i know everything to do but my question is can someone tell me about the fuel swapping. (injectos fuel pump etc...)what all would i have to do???
thanks
Old Jul 23, 2004 | 11:40 AM
EL Vap133's Avatar
Default Re: swap (hatch91JDM)
It would help to know what car you have.
Old Jul 23, 2004 | 12:08 PM
Ass$nyper's Avatar
Pirate General...YARRRR
hmm I assume from your cryptic post you have an STD *its ok my girl gave me the clap once but thats another story....... No i'm kidding*
Ok ok back to topic you have STD model civic and your asking what is easier swap a SI D16 or b16a? well both you'll need to rig up the MPFI system those motors use *you can run DPI with the SI motor but it'll suck* but the b16 will take some more work a mount kit and wiring out the wazzoo but very worth while.
The easier and cheaper swap would be the SI motor swap i bet if your handy you can do it alone in a day
The b16 would be alot more power and more costly but its harder and if your not good with working on cars wiring etc i would sugest sending to a shop
Old Jul 23, 2004 | 01:56 PM
JapJunkie's Avatar
It should about which motor is better i.e more horsepower. Either or you should take the time to learn how to wrench on your own car and figure out how to wire MPFI and other stuff. Its not that hard, unless ur lazy like my *** and dont feel like getting into to **** you dont want to deal w/. Then you should go for the easier swap, but give urself a challenge. Go B16 or do a sinlge cam but for sure bust the MPFI And after ur done u feel like your the **** and you can teach others
Old Jul 23, 2004 | 02:14 PM
kaoss_11's Avatar
B A N N E D
Default Re: swap (hOnDadiCt)
I tried the wiring myself and its hard but i can say i didnt give it an honest effort like i should have. But now i wish i had did it myself.
you see, i have a std model civic and i do have some car knowladge but i am trying to learn more. i do have a lot of friends that do swaps on their own and i'm sure they would do it for me but before i let it happen, i wanna know what's going on. i know if i wanna do a swap for my hatch i am going to need new axels new engine mounts all that. but i wanna just find out the little things ya know???
BrianB16A2
33
Nov 13, 2013 12:20 PM
12345678910jdm
Jul 24, 2011 06:54 PM
xcathodex
Mar 31, 2003 10:26 PM
DevinW
Mar 20, 2002 05:37 AM
