JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny
Old Jul 23, 2004 | 10:04 AM
Mach slo's Avatar
Default JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny
I sell whole syncro ring kits for all hydro's and some cable trannys including ys1. I currently have a auctions up on ebay, or we can work outside ebay as well, if you like. I also can get most any other manual trans synchro rings. Send me a message with your special request.. Free Shipping with Buy It now, $15 flat for everyone else, continental U.S. only. Ask about our new bearings, and seals rebuild kits.
YS1 cable/97-2000 type R
http://cgi.ebay.com/ebaymotors...SE:IT
GSR hydro
I also rebuild transmissions, so if you decide to sell your grindy tranny instead of rebuild it, sell it to me
Modified by Mach slo at 3:08 PM 7/26/2004
Modified by Mach slo at 2:28 PM 7/30/2004
Modified by Mach slo at 2:30 PM 7/30/2004
Old Jul 23, 2004 | 11:28 PM
Mach slo's Avatar
Default Re: JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny (Mach slo)
bump
Old Jul 24, 2004 | 12:26 AM
emendgroove1's Avatar
im me with more info please...really really interested.
Old Jul 24, 2004 | 08:19 AM
Mach slo's Avatar
Default Re: (emendgroove1)
sent you IM, and bump.
Old Jul 24, 2004 | 08:04 PM
Mach slo's Avatar
Default Re: (Mach slo)
bump
Old Jul 26, 2004 | 10:49 AM
Mach slo's Avatar
bump
Old Jul 27, 2004 | 07:28 PM
Mach slo's Avatar
bump
Old Jul 28, 2004 | 12:24 AM
tallblondkid's Avatar
i dont want to buy, but i have an del sol b16 tranny with an after market LSD (not sure which one), i believe kaaz or quaiffe.... it grinds second, and i figure its just easier for me to sell it and buy a new one.... anyway, if you want it let me know, hit me with a good offer and its yours
Old Jul 28, 2004 | 12:54 AM
NumberB's Avatar
pmed
Old Jul 28, 2004 | 04:09 PM
Chris22215's Avatar
Default Re: JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny (milb16a)
I'm interested in how much it would be to rebuild my 95 ls tranny, it's starting to grind in 3rd. oh and what's your turn around rate?
Old Jul 29, 2004 | 04:47 PM
Mach slo's Avatar
Default Re: JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny (Chris22215
any and all labor charges are $160. Example. synchro rings install $160. synchro ring and lsd install $160. You would still need to buy the rings. LS rings are $200 shipped, thats all the synchro rings in the transmission 1-5 and reverse. Its best to replace all while our in there, because you have to pull 4,5, and reverse to get to 3rd. Its also best to catch it as soon as it starts grinding, if not you may destroy the dogs on the sleeve. Sleeves can't be bought by themselves, only as part of a whole 3/4 hub sleeve rings and gearset, which are only available from honda and costs almost 300$ just for the 3/4 ones. Thats almost 900$ to replace them all. Catch it soon, replace all the synchro rings in the tranny, run good fluid(honda mtl/gm synchromesh), change the fluid often.
Modified by Mach slo at 9:18 PM 7/29/2004
Old Jul 30, 2004 | 10:31 AM
Mach slo's Avatar
bump
Old Jul 31, 2004 | 11:58 AM
Mach slo's Avatar
bump
Old Aug 1, 2004 | 10:59 PM
Mach slo's Avatar
bump
Old Aug 3, 2004 | 01:56 PM
Mach slo's Avatar
bump
Old Aug 3, 2004 | 01:59 PM
Milk Man's Avatar
do u have the whole ls tranny? if so how much hydro
Old Aug 3, 2004 | 02:37 PM
Sliced Beard's Avatar
Default Re: JDM type r LS b18c b18b b18c5 b16 synchro gsr syncro YS1 S80 Y80 transmission tranny (HelloMr.Sa
you do know that they are both identical
al b-series trannies(hydro and ys1) use the same syncro's
Old Aug 3, 2004 | 03:40 PM
Mach slo's Avatar
B16a y21 hydros are double syncro'd for second gear. Y80 LS hydro are not, So not all hydros are the same.
Modified by Mach slo at 8:03 PM 8/3/2004
Old Aug 3, 2004 | 04:09 PM
Mach slo's Avatar
The rings are different. They are all different part numbers, with the exception of 1st gear. There part numbers are different, and they all mic different.
Old Aug 4, 2004 | 09:23 PM
Milano98teg's Avatar
good info
Old Oct 12, 2004 | 04:02 PM
2.3vtec's Avatar
I think my 2nd gear syncro is going bad. I am currently getting the tranny pulled to replace the clutch and flywheel. How much for the set for an h22 tranny? Is this something most any mechanic can change out?
hondatuner20
Mar 14, 2006 06:38 PM
hammerdgolfer
May 13, 2004 08:42 PM
zojirushi
Oct 23, 2001 02:22 PM
