Accord trim
Old Jul 23, 2004 | 09:59 AM
liquiid11's Avatar
Default Accord trim
I have a 96 accord, seattle silver with black running trim on the doors, i also want to remove the black door handles and paint, i want to paint the trim the same color. I have the color, i just need to know how to remove those to paint.
Old Jul 23, 2004 | 10:46 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Accord trim (liquiid11)
The black trim going down the side of the door is glued onto the door. I think there may be 2 or 3 clip holding it as well but for the most part it's glued.
You would first need to heat the glue with a heat gun or blow dryer and then gently pull the molding off while removing the clips as well. Once it's off you'll need to remove the glue from the molding/trim pieces and then also from the door. Once all the glue is removed then you can re-glue the newly painted pieces into place. I can'r remember what the manual says to re-glue it with though.
Old Jul 23, 2004 | 11:22 AM
liquiid11's Avatar
Default Re: Accord trim (TouringAccord)
Well that sounds like a job, how about taping off around the trim, sanding and painting that? or would it be better to pull them off? Also, any ideas on the removal of the door handles??
Old Jul 23, 2004 | 11:25 AM
H-T Order of Merit
I would say removing them and then painting would turn out the best.
The door handles are much harder. You need to remove the door panels, the plastic covering the insides, I think the door lock mechanism and maybe some other stuff. I can't remember, I would have to look at my Helms but I'm at work and it's at home right now.
Old Jul 23, 2004 | 11:26 AM
liquiid11's Avatar
thanks.
journeyquest
May 3, 2014 08:17 PM
oarce05
Honda Civic (2001 - 2005)
Aug 3, 2012 11:01 AM
Blue10karat
Feb 9, 2005 07:27 AM
