climate control and speedometer wont light up!
Old Jul 23, 2004 | 09:20 AM
92eg6's Avatar
Default climate control and speedometer wont light up!
i have a 97 civic hb and the lights of my speedometer and climate control arent lighting up, anyone know why? this just hapened out of nowhere
Old Jul 23, 2004 | 09:21 AM
Ej1_coupe's Avatar
Default Re: climate control and speedometer wont light up! (92eg6)
did you turn the dimmer switch down by accident?
Old Jul 23, 2004 | 05:51 PM
92eg6's Avatar
Default Re: climate control and speedometer wont light up! (Ej1_coupe)
no its not that, its completeley off but the otehr lights like the cel,signal lights, high beam lights are working fine,
Old Jul 23, 2004 | 06:26 PM
RedStar101's Avatar
did you check the fuses just in case?
Old Jul 23, 2004 | 06:59 PM
camera obscura's Avatar
Default Re: climate control and speedometer wont light up! (RedStar101)
Almost certainly a fuse.
Old Jul 23, 2004 | 08:00 PM
ej1 pilot's Avatar
Default Re: climate control and speedometer wont light up! (camera obscura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camera obscura &raquo;</TD></TR><TR><TD CLASS="quote">Almost certainly a fuse.</TD></TR></TABLE>
i agree
Old Jul 23, 2004 | 09:02 PM
mrnicolas's Avatar
your dimmer switch could be faulty. when I bought my civic, it came with indiglo guages and the wires were hacked into for the dimmer switch for power for the guages. After I took the guages out, my climate control and gauges wouldnt light up. It has to complete a circuit for everything to work, I soldered everything back together and I have lights again.
so basically, try a friends dimmer switch after you check all your fuses.
Old Jul 25, 2004 | 10:03 AM
GreenGoblin21's Avatar
Default Re: (mrnicolas)
in my 2000 civic ex i have the same problem but only on one side. the passenger side seems to be out and the driver side looks ok. is it still a fuse of the light insde? any help or comments would be appreciated. thanx, ArT
drewbru
Lighting
Nov 21, 2017 08:55 AM
delsolo95
Honda Civic (2006 - 2015)
Dec 17, 2012 05:33 PM
Wrona
May 1, 2011 04:53 PM
VtecCivic93
18
Jul 24, 2009 05:31 AM
go2sleep
Sep 20, 2006 01:06 PM
