H22A Tranny Noise When I Let Of Gas Pedal While In Gear
Old Jul 23, 2004 | 08:06 AM
dacosta's Avatar
Default H22A Tranny Noise When I Let Of Gas Pedal While In Gear
My H22A w LSD just recently got a new flywheel and clutch package put on. Ever since, my Tranny is making noise when I let go of the Gas Pedal while in gear. The noise is most noticable while decelarating in 3rd & 4th gear.
Appreciate all advise / help / feedback.
Thanks in advance,
Darwin
Modified by dacosta at 7:54 PM 7/23/2004
Old Jul 23, 2004 | 08:43 AM
thehondaguru's Avatar
Default Re: H22A Tranny Noise When I Let Of Gas Pedal While In Gear (dacosta)
hmmm sounds like maybe clutch alignment? or somehing to that nature.
Was the flywheel used, new or resurfaced?
Old Jul 23, 2004 | 10:59 AM
dacosta's Avatar
Default Re: H22A Tranny Noise When I Let Of Gas Pedal While In Gear (95 lude)
The disc, clutch pressure plate, throw out bearing & flywheel were all new at the time of purchase.
Old Jul 23, 2004 | 11:10 AM
C M S's Avatar
I have the same set up. When I first did the swap that freaked me out too. All my stuff was new also, so after pulling everything apart and putting it back to gether, it turns out its just "chatter". Either clutch or LSD chatter! Hope that helps!
Old Jul 23, 2004 | 11:37 AM
dacosta's Avatar
Default Re: H22A Tranny Noise When I Let Of Gas Pedal While In Gear (1SICJDM)
Did your chatter ever go away?
Modified by dacosta at 1:11 AM 7/24/2004
Old Jul 23, 2004 | 04:12 PM
dacosta's Avatar
Do you have H22 OBD1 USDM ECU?
Old Jul 25, 2004 | 11:00 AM
ExTrix's Avatar
anyone looking for a m2b4 LSD trans for a h22
new 2nd and 3rd gear trans in perfect condition
need to get rid off asking $1,000.
Old Jul 25, 2004 | 12:43 PM
sandusk's Avatar
Default Re: H22A Tranny Noise When I Let Of Gas Pedal While In Gear (ExTrix)
my guess is that your throwout bearing is ratteling around and clanging off of the clutch fingers. my jeep is always making that noise, i finally cut a hole out of the bellhousing and watched it happen.
nus_dogg
Mar 25, 2009 07:53 PM
dangmedcalf
Transmission & Drivetrain
Mar 16, 2009 05:59 PM
dacosta
Jun 18, 2004 11:58 AM
1SlowSi
Feb 26, 2004 12:39 PM
