Help! My engine oil light came on and staying on.
Old Nov 26, 2001 | 07:46 AM
3rdGteg's Avatar
Default Help! My engine oil light came on and staying on.
I checked the oil level and topped it off, but that don't seem to be doing it. What could I possibly check? In the little owner's manual it says something with the oil pressure dropping? So what could I possibly check?
Thanx people. Appreciate your help.
Old Nov 26, 2001 | 07:54 AM
rtype11's Avatar
Default Re: Help! My engine oil light came on and staying on. (3rdGteg)
check your coolant overflow bottle, does it look like choco milkshake??, you may have broken your oil pump or headgasket you should be leaking everywhere by now. dont try to drive car until you determine what is going on.
Old Nov 26, 2001 | 09:02 PM
joemama's Avatar
New User
you might want to connect an oil pressure gauge and start your engine, if you have no pressure turn off the engine immediately.
Old Nov 28, 2001 | 08:24 PM
3rdGteg's Avatar
Default Re: Help! My engine oil light came on and staying on. (joemama)
Thanks, anything else I can do?
Old Nov 28, 2001 | 08:28 PM
four27's Avatar
You may have to have the dealer do a code readout or did you try and reset the green reset button just under the dash to the right of the steering wheel? It is normally used to reset the check engine light after the dealer fixes the problem. But you just may have a oil problem. I think you hold the button down for a few seconds while the key is in the accesory position or something like that.
Old Nov 28, 2001 | 10:02 PM
mingchi96
Guest
Posts: n/a
Default Re: Help! My engine oil light came on and staying on. (four27)
why dont you check the code. jump yr service connector and just count the number of times it reads and look at yr manual.
Old Dec 3, 2001 | 12:49 AM
3rdGteg's Avatar
Default Re: Help! My engine oil light came on and staying on. (mingchi96)
The oil light puts out codes like the check engine light?
Nukin
Apr 29, 2018 09:36 PM
SofireGuy
Feb 16, 2009 10:08 AM
Lithel
Sep 29, 2008 12:19 PM
shraz
13
Jun 8, 2006 08:11 PM
kandekilla
Jan 18, 2004 10:55 AM
