Help - compression test results
About 4-5 weeks ago I had a disappointing day at the dyno. I post my results and one of the many recommendations was to get a compression test done. Well I went to the local speed shop and they ran the test. They told me that my numbers were normal. Are they?
1 – 151
2 – 150
3 – 156
4 – 155
1 – 151
2 – 150
3 – 156
4 – 155
No, those numbers are low as hell. Should be like anywhere from 180-240 for stock ITR, depending on how well the motor was broken in and maintained.
A little part of me wants to say use a different compression gauge and try again.. because ALL your numbers are so low, and within tolerance of each other.
FWIW,
Mine gets 240, 230, 230, 240 and it's a stock R w/ 12 thou milled off the head.
FWIW,
If compression comes out low does that just mean that your stuck with a few less hp or does it mean that the motor will breakdown soon. It is my understanding that when the piston rings set, whether good or bad, they set for the life of the motor.
ChicagoMike
Jul 14, 2006 01:30 PM
