MOTOR MOUNT QUESTION
Old Jul 22, 2004 | 09:57 PM
piggs's Avatar
Default MOTOR MOUNT QUESTION
Is it a bad idea to run a DOHC with only 3 motor mounts?
(engine mount, tranny mount, and back bracket)
Oh and I have a six puck unsprung clutch.
And will the extra tranny mount be necessary?
Old Jul 22, 2004 | 10:02 PM
GZR4DR's Avatar
Default Re: MOTOR MOUNT QUESTION (piggs)
The other 2 mounts are actually suspension mounts, not quite the same as the 3 mounts you currently have on your car. If it were me I would definitely get the other 2 as it helps stiffen up the motor.
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
I'm not sure its the safest thing to do, but if the engine doesn't seem to move alot and you don't get on it too hard it might be ok for a bit, DON"T GET ON IT, thats what the mounts are for, to take the torque.
Old Jul 22, 2004 | 10:07 PM
hadehatch's Avatar
Default Re: MOTOR MOUNT QUESTION (Ahrpr)
If you do this dont think about launching it without expecting massive wheel hop and most likely contract between the engine and hood or strut bar..
The engine will move around like crazy.. you will feel it every time you start off and shift hard... Especially with that clutch..
The 2 lower mounts are the ones that really absorb the back and forth motion of the engine.. I wouldn't drive the car too much without them, believe me I've done it and its just not comfortable..
Old Jul 22, 2004 | 10:54 PM
piggs's Avatar
Default Re: MOTOR MOUNT QUESTION (hadehatch)
Well this is the thing, I had a DOHC installed recently into my EG6. The mechanic that did the work said nothing about these lower mounts. Now 2weeks later I was driving my car / i rev'ed out first and dumped it into 2nd and fucked up the tranny where the upper mount screws in. The bolts ripped the threads right out.
Now would this have happened if the lower mounts were put in?
Old Jul 22, 2004 | 10:56 PM
ABK's Avatar
ABK
those mounts only stop the motor from tilting when you launch. You might end up causing the damage to your other mounts when you launch not to mention, the massive amount of wheelhop you will get.
es_squared
Jan 27, 2009 07:22 PM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
castlenutz
Jun 8, 2005 01:05 AM
BobGnarly
Feb 12, 2005 01:15 PM
mingchi69
Feb 20, 2004 08:08 PM
