For guys that have indiglos on their EF, need help.
Old Nov 26, 2001 | 06:07 AM
TypeR0207's Avatar
Default For guys that have indiglos on their EF, need help.
I already have them all installed, I just need to know what wire to connect the hot wire to. I want to have it work with the regular lights, just like normal as far as when it turns on.
Any help as to exactly which wire (color/location) would be greatly appreciated!!
Old Nov 26, 2001 | 06:57 AM
B18b Turbo's Avatar
New User
Default Re: For guys that have indiglos on their EF, need help. (TypeR0207)
look at the top of the fuse box under the dash and their is two empty slots get a female connector and plug itinto the slot on the right that is a secondary parking light output make sure you fuse the wire and never wrap a wire around a fuse and shove it back into teh panel it can cause a fire
Old Nov 26, 2001 | 07:13 AM
Phatwhippin_CRX's Avatar
Default Re: For guys that have indiglos on their EF, need help. (LS CRIX)
or just solder it to one of the terminals on top the guage cluster circuitboard....
Old Nov 26, 2001 | 07:24 AM
markedOO1's Avatar
I wired mine up to the light on the cigarrette lighter...probably not the best place, but its easy and doesnt require any thought
Old Nov 26, 2001 | 08:08 AM
bryant's Avatar
Default Re: For guys that have indiglos on their EF, need help. (marked001)
i just wired it to the back of the guage cluster. where those + and - signs are. they come on when ever the car is started but oh well. makes wiring easy.
Old Nov 26, 2001 | 08:31 AM
TypeR0207's Avatar
Default Re: For guys that have indiglos on their EF, need help. (CR-X)
All good stuff .....
But I just got a buzzer for the lights (buzzes when they are on with the car off) and it is wired into the #2 and #3 accessory clips ........
And my POS doesn't have a cigarette lighter ......
Old Nov 26, 2001 | 10:00 AM
TypeR0207's Avatar
Guess I'll just do it to the "+" lead on the back of the gauges unless there is another way you can think of.
Old Nov 26, 2001 | 11:24 AM
FUP23's Avatar
New User
Wire it in to the dimmer switch. Thats the easiest way possible. Hot wire goes to the solid red wire, ground it on the black on. Dont worry about the other half red/black wire. Have fun
Old Nov 26, 2001 | 11:31 AM
markedOO1's Avatar
...there's a wire going into your head unit that goes on w/ the lights as well....
oj5joker
Jul 16, 2010 08:42 PM
el1cuban
Dec 27, 2008 06:18 PM
SIMATIC
Jul 30, 2003 01:19 PM
Jonathan_ED3
Sep 5, 2002 10:12 AM
S13 slide
Jan 20, 2002 10:35 PM
