HOW DO I REMOVE MY ALTERNATOR?
Old Jul 22, 2004 | 09:00 PM
ch4nq's Avatar
Default HOW DO I REMOVE MY ALTERNATOR?
i have a 92 civic cx (stock motor ) and my alternator keeps killing me when i slow down on the road. does any one have good write-ups on how to do this? anything? suggestions? any info would be great thanks..
Old Jul 22, 2004 | 09:04 PM
Kamin's Avatar
Default Re: HOW DO I REMOVE MY ALTERNATOR? (ch4nq)
what?
keeps killing you? explain more.
and you cant just remove the alternator, do you mean replace it?
BauleyCivic's Avatar
Risky Business
Default Re: HOW DO I REMOVE MY ALTERNATOR? (Kamin)
http://www.helminc.com
Honda---> shop manuals ---> 92 civic
Old Jul 22, 2004 | 09:07 PM
ch4nq's Avatar
i just need to replace it with a new one
Old Jul 22, 2004 | 09:13 PM
Luserkid's Avatar
Default Re: (ch4nq)
Take the 2 bolts out thats holding it in (a 12 and 14 i think) and then unplug it and put the new one in. Its really simple.
Now getting to it is another story
Old Jul 22, 2004 | 09:54 PM
Deemeetree's Avatar
Electrician
1. Disco battery.
2. Disco electrical connections to alternator.
3. Loosen adjusting bolt and through bolt and remove belt.
4. Remove adjusting bolt and through bolt and remove alternator.
5. Remove brackets if needed.
6. Install is reverse from removal.
7. Tighten through bolt to 33 lbs.
8. Tighten adjusting bolt to 17 lbs.
Drive your car on ramps and work from the bottom.
Old Jul 22, 2004 | 10:57 PM
Synergy001's Avatar
i had to take out the header on my car to bring the alternator out when it was unbolted because i didnt feel like taking out the axle.
Old Jul 22, 2004 | 10:59 PM
GdmLaz's Avatar
hmmmm you don't have to take out the axle or the headers 2 put a new alternator in I just did mine like 2 weeks ago is a bitch 2 get to it but you don't have to take it off
Old Jul 23, 2004 | 02:01 AM
menkio's Avatar
Default Re: (Slammed92hbonN20)
lol.. take out the axle.. haha.. funny kid. Anyways.. if you can take out the alternator.. which is just common sense.. don't play with your car. Just bring it to a shop.
Old Jul 23, 2004 | 08:01 AM
ch4nq's Avatar
Default Re: (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">lol.. take out the axle.. haha.. funny kid. Anyways.. if you can take out the alternator.. which is just common sense.. don't play with your car. Just bring it to a shop.</TD></TR></TABLE>
i dont want to take it to the shop because i dont want to spend no money. they ripp you off. i just want to learn this now so i will know how to do it in the near future.
Old Jul 23, 2004 | 08:08 AM
ej1 pilot's Avatar
Default Re: (ch4nq)
before you replace the alternator...just tighten the alt belt and see if that works, it is squeaking right? if it is my friend just tightend his and it stopped completely.
you need 2 14mm wrenches i think, tighten the bolts in the front and back of the alt
Old Jul 23, 2004 | 08:16 AM
delScho's Avatar
I keep reading these comments (this thread and others) about having to pull the brake booster (working above motor) or pull an axle or pull a header to get the alternator out... How are they in the way if you can work under the car? I've done a couple alternators on del Sols and EGs, and I've never had to pull anything but the alternator and unplug it.
Another tool that helps in tensioning the belt is a small pry bar or a really big screwdriver. Sometimes this helps when you are the only one working on the car.
Old Jul 23, 2004 | 02:49 PM
ch4nq's Avatar
Default Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">before you replace the alternator...just tighten the alt belt and see if that works, it is squeaking right? if it is my friend just tightend his and it stopped completely.
good idea, where is the second one anyways? i found only one
Old Jul 23, 2004 | 03:03 PM
ej1 pilot's Avatar
Default Re: (ch4nq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ch4nq &raquo;</TD></TR><TR><TD CLASS="quote">
good idea, where is the second one anyways? i found only one</TD></TR></TABLE>
i cant remember...i think its the 2 bolts in the middle of the pulleys
Old Jul 23, 2004 | 03:16 PM
ch4nq's Avatar
god dang it! so complicated! any pics?
Old Jul 23, 2004 | 03:17 PM
ej1 pilot's Avatar
Default Re: (ch4nq)
i dont have a digicam sorry
Old Jul 23, 2004 | 05:10 PM
BLUE EH3's Avatar
Help we my pennies
how do i hook up my odb0 to my odb1 engine harness
Old Jul 25, 2004 | 10:56 PM
Synergy001's Avatar
i tried pulling it out but there was no room unless i took the axle out. but i decided to take the header out instead. maybe the car u worked on didnt have power steering. anyways...it was a tight fit so i just pulled the header off. i got the job done and thats all that mattters. right?
Old Jul 26, 2004 | 01:59 AM
Declectic's Avatar
any manual that you pick up tells you to remove the axel in order to take out the alternator (thats what my buddies manual said) because we took out and replaced my alternator (i broke it on accident) on my EM1
we didnt feel like taking out the axel because thats more work than what we felt was involved
there are 2 bolts, you can see one from the top of the engine bay .. the other you gotta get uner the car for, just above the axels
like someone above said, pull the alternator back as far as you can and tighten it up and that will stop your suqeeks . . .
if not, and you have to pull it, pull it from the TOP .. its hard to get out, but you can get it out, think of it as a jigsaw puzzle
EDIT: oh yeah, make sure when your puttin the grounding wire back on the alternator, that that **** is TIGHT!!! i went thru like 2 batteries cuz i didnt realize it wasnt tightened down
TnC
Jan 27, 2011 12:13 PM
luigylima88
Mar 14, 2010 10:40 PM
--eclipse--
Jun 18, 2007 08:55 PM
Synthead
Jul 31, 2005 08:55 PM
