Integra Trouble StartIng
Old Jul 22, 2004 | 08:46 PM
Master23's Avatar
Default Integra Trouble StartIng
My integra won't start, it only cranks but doesn't turn on. How do i fix it?
Old Jul 22, 2004 | 08:49 PM
3.504's Avatar
Default Re: Integra Trouble StartIng (Jgears)
kinda vague... fuel pump problems maybe or ignition problems. those are two good places to start, along with timing belt might be snapped, and you might not be making compression.
Old Jul 22, 2004 | 09:06 PM
electronb16si's Avatar
Definately need to get more specific. With the informantion you gave it could be about a thousand things.
Old Jul 22, 2004 | 11:15 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: (electronb16si)
starter, distributor...motor, socks, replace'em all
seriously, like the two guys said above. you arent giving us anything to work with.
Old Jul 22, 2004 | 11:18 PM
Frankintegra's Avatar
Could be anything ! Fuse, Coil etc!
Old Jul 23, 2004 | 06:34 AM
au-gsr's Avatar
Default Re: Integra Trouble StartIng (Frankintegra)
start with cap and rotor
then coil
then ignitor
then main relay (which controls the fuel pump and feed)
then fuela related components.
my guess is this if it turns over and you aren't getting a flutter out of the rpm needle then the ignitor and coil will need to be replaced. and if those need to be replaced you might as well spend the extra 20 bux on a cap and rotor for a full distributor tune up.
i had a similar problem. car wouldn't start. replaced cap and rotor because the cap was cracked. then it started about 5 more times and rana total of 50 miles. then it **** the bed. i replaced the coil(which is the next cheapest part inthe distributors that go bad) adn it still woudlnt turn over. so i pulled it all apart againand replaced the ignitor.
i bought a main relay, but had no need to replace it as the car runs like a champ now. I also went two steps colder with denso iridium plugs. for 126,xxx miles, the car has a lot more pull then it did at 100,xxx miles. the only thing that is still onthe car that has not been replaced on the ignition side of things was the backend of the distibutor and the orignial plug wires.
always start with ignition then go to fuel. more than likely it is ignition related.
oh and since it has been really humid in colorado i have seen about 2-5 tegs a week in the dealership getting a distributor tune- cap, rotor, ignitor, coil . . . .
good luck
smoore117
Honda CR-V & Element
22
Nov 10, 2014 05:54 AM
ehJay
Mar 17, 2011 11:58 AM
ggreekggod
Feb 26, 2008 09:20 AM
bens_redeg
13
Jul 29, 2004 08:43 PM
micanned
Oct 3, 2003 07:11 AM
