o2 sensor removal from stock 99 ls cat?
I'm installing a new jdm itr header, hi flow cat, and apexi rs cat back exahust on my 99 ls integra. i'm running into trouble in removing the o2 sensor from the cat. I cannot remove the o2 sensor off the car because it is wired in. Only thing i can think of so that I can man handle the sensor is to actually cut the wires off and then resolder them back on. Any other suggestions before I do this?
Used the search feature but no posts on this.
buy the socket for a few dollars that has a slit to allow you to go around the wires.
or mark the wires so you know where they go, cut them and re wire them.
either or.
either or.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra99blue »</TD></TR><TR><TD CLASS="quote">what socket??</TD></TR></TABLE>
A special socket used for O2 sensor removal.
cool, sounds good. but what about the cat, its heat shield are covering the nut part of the o2 sensor and i can't get in. does the tool allow it to go weg through somehow or do i actually have to remove the heat shields to do it? If so I think i'm better off cuting the sucker down then to get the leverage.
