do i need to resurface my flywheel if I.................?
Well, here's the situation, I'm swapping in an h22 but I want to
use my centerforce clutch from my old h23 if the disc is still meaty enough.
If I bolt my old clutch to the h22 flywheel, will I have to resurface it?
If so, I might just use the h23 flywheel if it will bolt up. I mean hell, my
h23 flywheel is already lightened, maybe i'll just use it.
What do you guys suggest?
I would just use the H23 flywheel. H22 and H23 flywheels are EXACTLY the same.
If you mate the used clutch to a flywheel other than the one it was mated to before, you should resurface it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">yeah better off with ur old flywheel since the surface will match perfectly.</TD></TR></TABLE>
....and you'd be getting a lightened flywheel!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">
Awesome
i'll definately go this way if the clutch is in good shape
one other question, do i have to take off the flywheel to get
to the rear main seal anyway? I figured I should change this while the
engine is out. Sorry, I haven't studied up on the almighty
Helms enough yet
</TD></TR></TABLE>Awesome
Helms enough yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">Yep, the flywheel will have to come off.
So you're fixing the H23 for now?
Nope, I decided to swap in a jdm h22 w/the m2b4 tranny,
but I will be fixing the h23 so i'll have a spare on the side
And my my my, aren't we up late tonight </TD></TR></TABLE>
you know it
going on the regular 3 hours of sleep on the week nights.
sleeping is overrated
you know it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
Duh, you were just talkin about swappin the H22 and H23 flywheel!
****, when you can't read or think straight, I'd say it's not overrated! I just am too used to sleeping 12 hours a day, I can't handle getting little sleep..........yet I can't sleep!
Blah, if only I hadn't gotten sick from it the other night, I'd drink myself to sleep!
I just am too used to sleeping 12 hours a day, !</TD></TR></TABLE>
you're like a big bear
"swingers"
another question, in the helms it says you have to use a
couple special tools like a clutch alignment disc, ring gear holder,
clutch alignment shaft, and a handle. Can I get by with just
an alignment tool that fits my clutch?
"swingers"another question, in the helms it says you have to use a
an alignment tool that fits my clutch?</TD></TR></TABLE>
the ring gear holder keeps the flywheel from turning while loosening/tightening the bolts.
a screwdriver and/or some vice grips will work too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude »</TD></TR><TR><TD CLASS="quote">yeah thats all I ever use. I never even heard of that **** before.</TD></TR></TABLE>
Ditto
Ditto
yeah just put one of the tranny bolts back onto the block, then use a piece of wood, or a big screwdrive or something to hold the flywheel from turning when u TQ the bolts.
as far as the alignment tool goes, its easy with one, but u can get away without one, just use a ratch handle or screwdriver handle or something, whatever fits and keeps the disc centered while u bolt down the pressure plate is good,
