B16 auto swap?
i got a auto eg coupe and wanted to know if anyone has done a auto b16 swap? i really need to keep my car auto so don't talk me out of the auto.... what is it exactly the parts that i need? is it a straight bolt in affair or does it need any modifications or mount kit...? any info would help....
well i think it should be a straight swap but some people say that you have to so some banging on the frame.... but if i'm wrong correct me...
so u have a d series in there that is an auto? i didnt realize they made an auto b16 tranny, but u could always go for an auto ls tranny or something. eithe way, should bolt in if its already auto.
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
you can do that, but if you want to have better use of hte power, id try to use a manual, maybe you have a buddy that could teach you, the manual swap wouldn't be too bad besides the clutch and all. if you go into the FAQ up top and they tell AT to MT conversions. Good luck with the swap tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahrpr »</TD></TR><TR><TD CLASS="quote">you can do that, but if you want to have better use of hte power, id try to use a manual, maybe you have a buddy that could teach you, the manual swap wouldn't be too bad besides the clutch and all. if you go into the FAQ up top and they tell AT to MT conversions. Good luck with the swap tho.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahrpr »</TD></TR><TR><TD CLASS="quote">you can do that, but if you want to have better use of hte power, id try to use a manual, maybe you have a buddy that could teach you, the manual swap wouldn't be too bad besides the clutch and all. if you go into the FAQ up top and they tell AT to MT conversions. Good luck with the swap tho.
thanks...
any how to info on how to do the b16 auto swap into an eg....?
</TD></TR></TABLE>thanks...
yeah I heard of auto b16s. I don't know if it's going to be easy to put in a b series into car that had auto eg d series. I don't know if they made a manual tranny conversion mount for b series, they do have it for d series. So if they don't make those mounts you will have to get a manual tranny mount bracket of the manual car and weld it on in place of the auto one. Seriously though it's not worth swapping an auto b series, if you are going to get your hands dirty do it right the first time.
i'd do the manual conversion.
auto b16's had less aggressive cams (intake, i think?..**** i might be wrong).
rev limit is 7.8
man i might be off with my specs...someone fill in. i know auto b16's are slower, i've driven both kinds in a DA.
rev limit is 7.8
i don't know **** about if it will fit but http://www.zerolift.com sells auto B16s. They're right by me up in Cincinnati, i've heard some good things about them
