What engine harness?
Old Jul 22, 2004 | 05:34 PM
EGTHU6's Avatar
Default What engine harness?
I just got a JDM 2nd gen B16 that i am putting into a 95 CX, and i wanted to know if i use the wiring harness that came with the b16, or do i have to use the harness from my CX's original motor...
Old Jul 22, 2004 | 05:46 PM
EGTHU6's Avatar
Default Re: What engine harness? (RubixEG6)
Bump... Please i need this info quick
Old Jul 22, 2004 | 05:48 PM
JDM EJ1 95's Avatar
if the engine is JDM you cant use the harness.. just use the Dseries and wire for vtec, knock and IAC
Old Jul 22, 2004 | 05:49 PM
JDM EJ1 95's Avatar
Default Re: What engine harness? (JDM EJ1 95)
wait i dont think you have to wire for IAC bc its obd1 but im sure u have to wire for vtec and knock
Old Jul 22, 2004 | 06:58 PM
93Civac's Avatar
Did the 95 CX have the sohc vtec?
I think with the b16 you can use a 94-95 gsr engine harness and if your car is already wired for vtec then it should be plug and play. If the car is not wired then you would have to run them.
Old Jul 23, 2004 | 02:21 PM
EGTHU6's Avatar
Default Re: (93Civac)
No my civic is non-vtec, anyway i already hooked up my CX's original harness to the B16, I have now started to wire in the VTEC, which brings me to my next question, what kind of pins do i need to plug the vtec wires into the ECU the ones i am using are too big to plug into the ECU harness, any suggestions?
Old Jul 23, 2004 | 02:32 PM
JDM EJ1 95's Avatar
Default Re: (RubixEG6)
i think radio shcak might have them
Old Jul 23, 2004 | 02:48 PM
EGTHU6's Avatar
Default Re: (JDM EJ1 95)
Do you know excatly which pins they are, or maybe the size?
Perkul8r
May 14, 2009 09:14 PM
b20beast978
23
Jun 11, 2007 09:52 AM
Mr. Roboto
Dec 10, 2006 06:59 PM
boostmywankle
10
May 22, 2005 12:31 PM
JSPECEX
May 18, 2005 09:11 PM
