Where did you guys order you ITR rear sway and mounting kit?
What kind off spring rates are you running. I am not trying to tell you what to do but I experienced subframe tear out on my daily driver(Never Tracked) because I had low spring rates. If yours are low I would recommend buying a Comptech, SRR, or Appollo Rear swaybar/tiebar setup. The ITR rear is probably too big for civics and their weak subframes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">What kind off spring rates are you running. I am not trying to tell you what to do but I experienced subframe tear out on my daily driver(Never Tracked) because I had low spring rates. If yours are low I would recommend buying a Comptech, SRR, or Appollo Rear swaybar/tiebar setup. The ITR rear is probably too big for civics and their weak subframes.</TD></TR></TABLE>
Well I have the Neuspeed Full Thread Coilovers (race spring). I tried to look up the spring rates but cannot find it. I'm pretty sure they are low.
Anyone know what the spring rates on those coilovers are?
I forgot to say that I will have the GSR rear brake conversion along with the trailing arms. I've heard of a few subframes tearing, thanks for the info
Anyone else experience this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by futuresi »</TD></TR><TR><TD CLASS="quote">Where did you guys order you ITR rear sway and mounting kit?</TD></TR></TABLE>
have you tried passwordjdm? or the honda-tech classfieds?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">
have you tried passwordjdm? or the honda-tech classfieds?</TD></TR></TABLE>
I've looked in the classifieds but all of the ones that I've found where sold. Didn't know passwordjdm had them I will check that out, but I still need to find out about this subframe subject...
I can't find the spring rates either. You might have to call nuespeed. Beaks also sell the complete kit minus the endlinks. Check with http://www.robearracing.com on a price for the Appollo rear swaybar/tiebar kit. i put this exact same setup on my car after the subframe tearout. if you do some reading you will find a thread i posted in about this exact same problem and it was agreed upon that the spring rate makes a difference.
From what I'm reading maybe it would be best to stick with the same manufacturer and get a neuspeed front/rear sway combo to go along with the coilovers.
Now I need to find out how big that bar is. Wouldn't that sound like the best way to go?
Modified by futuresi at 3:50 PM 7/23/2004
http://www.beaksproducts.com you can get bar, reinforcement, endlinks etc... through him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">Truthfully I would probably buy the SRR or Appollo rear combo. It is probably cheaper and has added safety.</TD></TR></TABLE>
I'm looking at that site and I only see an application for the 96+ civic for the appollo, also if I go with that setup what front sway should I match it up with?
Modified by futuresi at 4:17 PM 7/23/2004
I was thinking you owned an EK. Look at http://www.perpetualconcepts for the SRR combo for the EG. As for the front I don't really know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT »</TD></TR><TR><TD CLASS="quote">I was thinking you owned an EK. Look at http://www.perpetualconcepts for the SRR combo for the EG. As for the front I don't really know. </TD></TR></TABLE>
No its for the 94 coupe
"the project car of 5gcivic.com"
deviant1
Aug 25, 2004 07:23 PM
xhatchracerx
Apr 16, 2004 04:28 PM
