could your motor burn oil even if compression numbers are accurate?
Old Jul 22, 2004 | 03:53 PM
typeeg's Avatar
Default could your motor burn oil even if compression numbers are accurate?
A friend of mine has an ITR swap and lately he's been burning a lil oil. He also see's some white smoke out the tail pipe when he's in vtec but nothing too major. First thing that came to mind was rings but we did a compression test and numbers were in line. 240psi across..
So why would he be burning oil and smoke out the tail pipe if numbers are good?
Old Jul 22, 2004 | 08:00 PM
Tbone's Avatar
Default Re: could your motor burn oil even if compression numbers are accurate? (BrokenEF9)
Could be a few things, tell him to have a leakdown..Valve seals will not change cr#'s.
benji7288
20
May 29, 2009 08:16 AM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
FOrSfEd
Jun 1, 2004 09:02 AM
CRX SiR T
Nov 24, 2003 12:49 PM
