overheating?
Old Jul 22, 2004 | 03:51 PM
RedHackBatch's Avatar
Default overheating?
i was driving in the interstate and about after 45 minutes of driving goin about 80 mph, i notice my temp guage unsually higher then normal. i put it in nuetral and it went back down to normal, but if round 80 or past the temp goes way up. if driving normal (40) then its normal. what could this be?
Old Jul 22, 2004 | 04:09 PM
3.3.3's Avatar
Default Re: overheating? (RedHackBatch)
could be a lot of things. did you check your cooling system for any leaks?
is the car puffing white smoke?
yes i have plenty of coolant so i dont think there is any leaks. and i dont think there is smoke from the exhaust but i stopped at a gas station and it started smoking. smoke was coming from somewhere under the IM
Old Jul 22, 2004 | 04:12 PM
and after the smoke i drove another hour and 45 minutes back to town and there was no more smoke
Old Jul 22, 2004 | 04:19 PM
dantastic's Avatar
sounds like a leak from a hose under the i/m. check your coolant level again. i bet its low
Old Jul 22, 2004 | 04:23 PM
ok will do
Old Jul 22, 2004 | 04:25 PM
nurvcom..'s Avatar
check you coolent for oil it that make it do that.!!
i had 93 lx it had a pin hole in head gasket and it got oil in coolent then after a little after a week the hole got bigger. i had to change head gaskets..
Old Jul 22, 2004 | 04:33 PM
did not find any leaks
Old Jul 22, 2004 | 04:35 PM
Default Re: overheating? (nurvcom)
coolant does seem a bit darker then usual. i think that might be it.
Old Jul 22, 2004 | 04:39 PM
nurvcom..'s Avatar
ya dran all coolent and see if it turn dark .. it should turn dark after driving it for 15min
if you see like little dot of oil in it you are going to need new head gasket
Old Jul 22, 2004 | 04:50 PM
ok thanks
Old Jul 22, 2004 | 05:43 PM
nurvcom..'s Avatar
Default Re: (RedHackBatch)
happy to help
ps let me know if it works
nurvcom@hotmail.com
hulsey
16
Mar 19, 2012 12:00 PM
khmers0uljah
Jun 7, 2009 12:33 PM
Ozne99
May 27, 2008 08:36 PM
thesoundofturbo
Apr 3, 2008 07:41 AM
blumpfish
Jun 18, 2006 09:23 PM
