horible responce
Old Jul 22, 2004 | 03:39 PM
T--Rex's Avatar
Default horible responce
Ok, I just swapped a b16a into my crx dx, now when i rev the engine i hear the intake take a gulp of air and it serioueley takes about a secound to even begin reving up. Any ideas what that could be?
Old Jul 22, 2004 | 03:44 PM
civicboisi's Avatar
Default Re: horible responce (Matrix_Zero)
did you rewire the harness or buy a pre-wired one already? I'd recheck the wires if you did it yourself...Bump for a local
Old Jul 22, 2004 | 03:58 PM
T--Rex's Avatar
Default Re: horible responce (civicboisi)
bought it pre-wired
Old Jul 22, 2004 | 04:05 PM
rodrez.'s Avatar
Check the simple stuff first, like your timing. Make sure the timing belt isn't off a tooth.
Old Jul 22, 2004 | 04:11 PM
dantastic's Avatar
Default Re: horible responce (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">Check the simple stuff first, like your timing. Make sure the timing belt isn't off a tooth. </TD></TR></TABLE>
sounds like timing to me too... when i first installed my b16, the timing was off, and i felt the exact same thing
Old Jul 22, 2004 | 04:12 PM
T--Rex's Avatar
checked the timing. it's good.
Old Jul 22, 2004 | 04:28 PM
h22John's Avatar
Clogged cat?
Old Jul 22, 2004 | 04:37 PM
T--Rex's Avatar
Default Re: horible responce (h22John)
no cat
Old Jul 22, 2004 | 05:48 PM
h22John's Avatar
O2 sensor? Maybe it's always in closed loop? I dunno, just throwin stuff out.
Old Jul 22, 2004 | 05:50 PM
h22John's Avatar
Also is this condition occuring just during free reving the engine or durring acceleration with the engine under load? I have a 00 b16 and it revs really slow too when there is no load on the engine, drives great though.
Old Jul 24, 2004 | 12:40 PM
T--Rex's Avatar
only with no load
Old Jul 24, 2004 | 01:42 PM
realblag's Avatar
If you have a short ram on it, it will make a loud chug sound and then rev. Its because when you flip the throttle from idle to wide open, there is a huge pressure drop in the intake. It takes a split second for the air to get through the filter and make it to the intake manifold so the engine actually has something to "inhale" and burn (rev up).
Modified by realblag at 6:12 PM 7/24/2004
Old Jul 24, 2004 | 03:41 PM
T--Rex's Avatar
Default Re: horible responce (realblag)
i have no filter on it currently. I just installed the engine and haven't got one perminently installed. I do have a cone i attach to the intake but it does it weather it is on or off.
OGCRV2001
Honda CR-V & Element
18
Feb 12, 2015 11:54 AM
journeyquest
Sep 10, 2013 05:48 AM
luvs2spooge
May 18, 2007 05:42 PM
sslude
Jun 25, 2004 07:53 AM
Comp97GSR
May 23, 2003 06:29 AM
