changing to synthetic causes clicking noise from head?
Old Jul 22, 2004 | 03:19 PM
pbizzlegsr's Avatar
Default changing to synthetic causes clicking noise from head?
after running castrol gtx for about 70k on a gsr..then changin to mobil 1 synthetic..would that cause the head to make clicking noises..from the cam gears area..with a moon cut cover..
Old Jul 24, 2004 | 01:38 PM
bukbukintegra's Avatar
Default Re: changing to synthetic causes clicking noise from head? (pbizzlegsr)
i don't think the oil change could've caused that, o and by the way the clicking sound might be valve tap, you might have to adjust the valves if that is the case. but i don't think the oil change could've caused that.
Old Jul 25, 2004 | 04:01 PM
cyr0ch's Avatar
Default Re: changing to synthetic causes clicking noise from head? (bukbukintegra)
ya, sounds like valves need adjustment. did you put thinner weight oil in? that might make the difference on the valve knock due to the oil change. other than that, thats all i can think of.
Old Jul 25, 2004 | 04:17 PM
tnord's Avatar
Default Re: changing to synthetic causes clicking noise from head? (cyr0ch)
do you guys have hydraulic lifters?
Old Jul 26, 2004 | 07:36 AM
scatuli's Avatar
Default Re: changing to synthetic causes clicking noise from head? (tnord)
by any chance do you use a fram oil filter?
Old Aug 2, 2004 | 12:41 AM
pbizzlegsr's Avatar
valves were adjusted 3 weeks ago..still there..hamp filter used..could it be that its normal since the cover is cut and its way louder cliking..
Old Aug 2, 2004 | 06:02 AM
DAsix's Avatar
...uh......yeah!
92eghb
20
Apr 17, 2012 07:16 PM
Jhicks
Feb 3, 2012 05:58 AM
roycivic92
11
Oct 9, 2009 06:16 PM
97BB6Type-SH
Nov 24, 2007 05:12 PM
Volcom
Jul 8, 2002 01:47 PM
