Built engine sitting for 1 month + w/o starting... what to do ?
Hey guys... got a built dohc engine with OEM bearings that has been sitting for over a month and has not been started in that time.
The battery is still fine... but I cannot start the car, but can prolly crank it over (no ecu and can't get one yet).
Soooo.... when I do get an ecu in about a week or so... any tips on what exactly I should do to make sure everythings kosher when I actually do crank it up ?
maybe pull the valve cover off and give the cams a good coating of cam lube/engine oil/assembly lube or something like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">Disable the fuel pump and crank the motor for 20-30 seconds to build some oil pressure.</TD></TR></TABLE>Do that without spark plugs installed. That way there's less force on the bearings for the first few seconds before the oil gets there. Prime the oil pump & fill the oil filter so the oil gets there faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Do that without spark plugs installed. That way there's less force on the bearings for the first few seconds before the oil gets there. Prime the oil pump & fill the oil filter so the oil gets there faster.
Exactly, and do what was said before, pour oil all over the top end, rotate once, pour more. Just be sure you dont already have 4 qts in there when you do this.
Or donate the motor to a kid in ft.lauderdale who spun a bearing on his LS-T set up
. Anthony the ECU is at Daves and i have no car to bring it to your wife. Do you want me to have cuesta get it and bring it to her? Call me or pm me. L8er homie.
so basically do just like when you start a fresh engine for the first time.... gotcha.
I will prolly change the oil before starting... that way I can lubricate the top end one time.
Thanks for the info.
PM to you Trent.
PM to you Trent.
