LS/VTECvs.F20B
Old Jul 22, 2004 | 03:05 PM
EIT_certified's Avatar
Default LS/VTECvs.F20B
i plan on spending the money to get the motor,whichever it may be,done right the first time.the problem lies on chosing between the LS/VTEC and the F20B.i want to stay all-motor and have a reliable street car.i'm not sure whether i'm going to stroke the LS/VTEC,but regardless of the fact,i would like a nice setup.with the F20B,i was planning on adding some Jun High-Lift cams or Stage2R's, valvetrain,cam gears,PnP,and possibly an Accord Euro-R intake manifold with stock block.
as for the LS/VTEC,once again i'm not sure on stroking,but i plan on building the motor from the block on up......such as Wiseco pistons,IB spec rods,Toda spec C's,valvetrain,cam gears,PnP,Skunk2 intake manifold.....yaddah,yaddah,yaddah.
i've figured the LS/VTEC to end up way more costly than the F20B,but with the aftermarket products listed,which do you guys think will end up being better in the long run(give or take a few more aftermarket products)
thanks
Modified by sheemo3 at 9:42 PM 7/22/2004
Old Jul 22, 2004 | 07:48 PM
Default Re: LS/VTECvs.F20B (sheemo3)
anyone?
Old Jul 22, 2004 | 07:59 PM
Sliced Beard's Avatar
you can build a rather decent LS/VTEC for under 2000 that will make nice power
Old Jul 23, 2004 | 07:55 PM
cpforyou's Avatar
Default Re: LS/VTECvs.F20B (dirtyd463)
I would rather get an F20B. It has 11.0:1 Compression right out of the box. You can use Skunk2 Stage II Camshafts or JUN Camshafts, and it'll be very happy motor. You can also rev this thing pretty high. It's stroke is shorter than a LS Crankshaft, and it's R/S Ratio is higher than that of a GSR Motor.
What more can you ask?
Old Jul 23, 2004 | 08:38 PM
uncle's Avatar
Default Re: LS/VTECvs.F20B (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">I would rather get an F20B. It has 11.0:1 Compression right out of the box. You can use Skunk2 Stage II Camshafts or JUN Camshafts, and it'll be very happy motor. You can also rev this thing pretty high. It's stroke is shorter than a LS Crankshaft, and it's R/S Ratio is higher than that of a GSR Motor.
What more can you ask?</TD></TR></TABLE>
F20B
Old Jul 23, 2004 | 09:10 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
f series is s2k, right?
Old Jul 24, 2004 | 06:19 AM
uncle's Avatar
Default Re: (MugenDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">f series is s2k, right?</TD></TR></TABLE>
F20C is s2k.
moyospeed
May 13, 2010 01:03 PM
EIT_certified
Jul 23, 2004 04:50 AM
slowww b18b1
Feb 23, 2004 08:11 AM
eg6sir-s
Mar 22, 2002 08:44 PM
