V6 2000 with 160k
Old Jul 22, 2004 | 01:00 PM
HotGoldfish's Avatar
Default V6 2000 with 160k
Hey guys!
I just bought an Accord V6 with 160k. the engine is very quite and the car runs great. I want to change the regular engain oil to syntetic one. is this ok, what kind should I buy and what filter. I am planning to heve this car for a wile so I have no problem to spend that money.
In addition what do u think about the K&N air filters?
Thanks much! I have been reading this forum for years and you r great guys.
HotGoldfish
Old Jul 22, 2004 | 01:05 PM
EX-JAY's Avatar
Default Re: V6 2000 with 160k (HotGoldfish)
I think your car has too many miles to switch over to synthetic oil. Someone correct me if I am wrong.
As for the K & N filters, you can't go wrong with them. All you do is clean and reuse them.
Old Jul 22, 2004 | 01:06 PM
PhatboyNYC's Avatar
With that many miles. you're probably better off using a synthetic blend.
K&N filters are great. You can either buy the drop in filter to use in your stock airbox or an AEM intake with the K&N cone filter.
Old Jul 22, 2004 | 05:26 PM
89_LXi's Avatar
Default Re: V6 2000 with 160k (PhAtBoY Si)
160k isn't all that much.... if the motor is in good shape and the oil has been regularly changed in the past, then you'll be perfectly fine switching to synthetic. I switched mine from dino oil to full synthetic (Mobil 1) at 260k miles and have been using it since with not a single problem, and it still doesn't burn a drop. The only reason you should ever be worried about switching to synthetic is if you already have bad leaks or are burning oil already. If not, switch away! What's the worst that can happen? If you don't like it, switch back!
Old Jul 23, 2004 | 07:08 AM
Default Re: V6 2000 with 160k (89_LXi)
the engine is very quite with no leaks, i switch to syntetic,which one should I buy the 10w 30, 10w 40, or20w 50?
Thanks much
HotGoldfish
Old Jul 23, 2004 | 10:46 AM
Kavehman's Avatar
since you live in florida either stick with 10w30 or the 5w30 which is what honda reccomends.
In my opinion if you change your oil every 3k then its not necessary to use synthetic. Regular oil will work just as well. Thats just my opinion though.
Old Jul 23, 2004 | 12:27 PM
02accordsir's Avatar
Hey i have a 02 cord with about 50k on it, I used synthetic since day one, but last time tried this Royal Purple stuff. From what i read about it, its supposed to be the best stuff out there and is used for when you get on your car a little more and sometimes can help out with high milege engines. Dont know if itll work for you, but i definately felt a little difference in cold starts.
Old Jul 25, 2004 | 10:55 AM
Default Re: V6 2000 with 160k (02accordsir)
Thanks 2 u all
Old Jul 25, 2004 | 02:40 PM
Justin Klemgold's Avatar
Default Re: V6 2000 with 160k (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">since you live in florida either stick with 10w30 or the 5w30 which is what honda reccomends.
In my opinion if you change your oil every 3k then its not necessary to use synthetic. Regular oil will work just as well. Thats just my opinion though.</TD></TR></TABLE>
Synthetic oil is superior to dino oil in just about every way...it flows better during cold startups (read: better protection) and protects better at high temps...also doesn't break down as easily...all of this is scientifically proven....
I just switched over to Mobil 1 SuperSyn at 248,000 miles on my 91 Accord...no problems whatsoever....that whole "If your car is high mileage, don't switch to synthetic" is the biggest bullshit myth you will ever find...those people who claim the switch caused leaks don't give the whole story...
I'm at 251,000 right now and the engine continues to run flawlessly with zero leaks...
ahmad-a
Apr 12, 2007 12:44 PM
teler86
53
Nov 8, 2005 10:07 AM
honda3431
Sep 4, 2005 11:47 AM
1998_4dr_gsr
May 19, 2005 05:53 AM
LiLOtaku
Jul 27, 2003 08:02 AM
