see if you can fix this problem???
i have a 94 4 door and there is a connection that goes from the drivers side door the the back inside of the drivers side fender panel..if you open the door you can see it well then
so the door lock, window motor and everything else runs threw that
how do u fix this if it breaks at the door with out going to the dealership they just want to dam much..
first buy a helms manual from http://www.helmsinc.com then determine what the problem is. if you findout that you are in need of parts go to your local junkyard or find a website that sells parts you need.
You mean the wiring harness bundled together at the door hinges? If that's all cut up you'll just have to start repairing it by splicing the wires back together. Or get a new harness.
ok so i got some attn
now the conduit that comes out of the fender drops down and has an attachment at the end which in turn plugs into a plastic connector that is attached to the door, the plastic connt has 2 clips on it that hold in in place and this is what is broken..
when the door opens or closes the windows speakers exc,, will not work iwent to a dealer and he said that the whole peice needs to be replaced...
i dont beleave him i just cant grasp the idea that because of one clip i need to replace the whole harnest system which runs for about 6-700 hundred,,anyone out there that has had this problem might know where to go.. ty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRIZACK »</TD></TR><TR><TD CLASS="quote">ok so i got some attn
i dont beleave him i just cant grasp the idea that because of one clip i need to replace the whole harnest system which runs for about 6-700 hundred,,anyone out there that has had this problem might know where to go.. ty</TD></TR></TABLE>
Get the harness piece from a junkyard and solder it in.
