emissions Q?
Old Jul 22, 2004 | 11:44 AM
dfoxengr's Avatar
Default emissions Q?
failed emissions today.
at 15mph the limit for NO ppm was 1144 i had 2107
at 25 mph it was 1034 i had 1808
HC at 15mph was 7 limit was 400 or so, at 25mph i had like 8 and the limit 500 or so.
i talked to the guy who i always go to see, and he says "guaranteed to pass" formulas only help with the hydrocarbon levels, and i need a new cat. i am too lazy right now to put one on, and its almost the end of the month, so i need another way to pass her.
B18B motor in a 92 hatch, meaning some of the PCV hoses arent hooked up too...would that affect NO levels?
any ideas?
Modified by hybridvteceg at 3:15 PM 7/24/2004
Old Jul 23, 2004 | 05:32 AM
dfoxengr's Avatar
Default Re: emissions Q? (hybridvteceg)
i also am using a p28 ecu, and i guess ill try to borrow an OBD1 LS ecu to try to pass with that.
any one have anymore ideas?
Old Jul 23, 2004 | 06:07 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">... any ideas?</TD></TR></TABLE>Retard your spark timing a bit. Use higher-octane fuel. High combustion temperature makes NOx. Hook up your PCV hoses, that might help a little.
How were your CO & HC numbers?? If they were way good, then look for a way to richen your mixture. Like slightly higher fuel pressure? Borrow an FPR from a GSR, but maybe that's TOO high?
Your NOx numbers aren't exactly 'borderline', so this simple stuff might not do it. If your cat is bad there's not much else to do...
Old Jul 23, 2004 | 07:22 AM
Ekasey's Avatar
Default Re: emissions Q? (JimBlake)
Agreed retard the timing nox is created by combustion temps in excess of 2500 degrees and excessive pressure.
most likeley your cat is dust
Old Jul 23, 2004 | 08:27 AM
dabigrog's Avatar
Default Re: emissions Q? (eLusive ek4)
i have same prob. if cat was bad would HC and CO levels be high also?
Old Jul 23, 2004 | 09:53 AM
Ekasey's Avatar
Default Re: emissions Q? (dabigrog)
Not always, there are 3 different active beds in the catalyst, one for each different ones can deterioate faster then others
Old Jul 24, 2004 | 11:13 AM
dfoxengr's Avatar
for some reason i have a hard time believing the cat is bad. any other ideas? do "guaranteed to pass" help with nox.?
my HC numbers are great, posted in the original thread.
Old Jul 24, 2004 | 11:53 AM
boostn420's Avatar
Check for exhaust leaks, the added oxygen can help clean HC's and make them really low while the heat from the extra oxygen may also help increase NOx at the same time. I had a friend with a punched cat blow super clean but he barely failed NOx because his exhaust leak, he replaced the cat and barely passed the HC's but it did. So its very well possible that your cat is toast.
Old Jul 24, 2004 | 08:17 PM
dfoxengr's Avatar
Default Re: emissions Q? (boostn420)
thanks i will. bump.
Old Jul 25, 2004 | 05:13 AM
dfoxengr's Avatar
off to battle of the imports
Old Jul 25, 2004 | 05:51 PM
dfoxengr's Avatar
only a few more days to fix this.
Old Jul 25, 2004 | 10:58 PM
Ekasey's Avatar
If you want to check the cat take a temp reading before and after the cat the cat outlet temp should be 200 degress hotter this means the cat is working
Old Jul 26, 2004 | 01:27 AM
dfoxengr's Avatar
thanks ill try to try that
Old Jul 26, 2004 | 11:27 AM
dfoxengr's Avatar
anyone elsE?
Old Jul 26, 2004 | 07:36 PM
dfoxengr's Avatar
Old Jul 26, 2004 | 11:12 PM
FalkenSiR's Avatar
right befor the test, take out ur air/intake filter, if lowers h2 and co levels.
Make sure ur car is at normal op temp.
dirty egr valve is a great minus also.
run the highest fuel grade u can, and put in some octane booster, because it uses a higher octane base in its composition.
those are facts that help.
Old Jul 27, 2004 | 01:28 AM
dfoxengr's Avatar
Default Re: emissions Q? (fast88std)
ok ill try to borrow someones stock airbox. thanks
does the guaranteed to pass stuff you can get at autozone reduce NOx levels?
Old Jul 27, 2004 | 09:39 AM
HmgLauj69's Avatar
cant believe no one mention this yet, carbon build up! heard berryman (i think) works, but more tend to go with sea foam (napa auto store)...i did, brought my nox level way down and passed smog, also try colder plugs, oil change, high octane gas you can get, retard timing although they hear in cali they check your timming, if you hc & co numbers are cool you do not need a new cat! from my experience anyway...hope that helps...oh by the way them octane booster thing = crap
Old Jul 27, 2004 | 11:20 AM
dfoxengr's Avatar
Default Re: emissions Q? (HmgLauj69)
thanks ill try seafoam.
Old Jul 27, 2004 | 02:58 PM
dfoxengr's Avatar
any other ideas?
Old Jul 27, 2004 | 04:11 PM
HmgLauj69's Avatar
cooling system maybe?
Old Jul 27, 2004 | 06:07 PM
dfoxengr's Avatar
which part affects emissions?
Old Jul 27, 2004 | 08:09 PM
Ekasey's Avatar
cooling system, ignition system, fuel system, emissions sytems of course, induction system, exhaust system
Old Jul 28, 2004 | 01:34 AM
dfoxengr's Avatar
where does coolant tie into emissions?
more ideas, i only have a few days left.
Old Jul 28, 2004 | 07:14 AM
dfoxengr's Avatar
ok i have "Guranteed to Pass" in the fuel tank now, just gotta run out all the fuel and fill up again. anymore ideas would be appreciated. ill let everyone know how the G2P went.
