where does the tranny fluid go in a 95 automatic accord???
this is probably a stupid question for ya but im not a accord guy and i thought it would be in the same place as a b series but i checked and there is no screw there......if anyone knows please tell me where do i put the tranny fluid in in a 95 auto accord and how muhc tranny fluid do i put in there. thanks
to drain its the bolt right near the passenger side wheel...
to fill its under the hood, look downwards a little behind the coolant reservoir, there should be a yellow coated dipstick...
the amount to refill, some put 1.5 qt, some use the full 2qt
The refill bolt is on top of the transmission case. The bolt is clearly label ATF. You can't miss it. Only manual transmissions get refill thru the dipstick. Automatic transmission take 3 quarts to refill. hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-JAY »</TD></TR><TR><TD CLASS="quote">The refill bolt is on top of the transmission case. The bolt is clearly label ATF. You can't miss it. Only manual transmissions get refill thru the dipstick. Automatic transmission take 3 quarts to refill. hope this helps.</TD></TR></TABLE>
i think you got it mixed up?
i have a automatic, i drain on the side and fill over the top...
and always needed 1.5-2 qts
KDoGx504
Oct 7, 2005 01:54 PM
CR-Vision99
Jun 25, 2005 04:13 PM
