OBD2 LS swap in OBD2B 00 hatch
Old Jul 22, 2004 | 10:28 AM
2 point 0's Avatar
Default OBD2 LS swap in OBD2B 00 hatch
i currently have a B16 swap in my 00 hatch. i have a 96 LS swap from my other car and want to put it into the 00 hatch. since it's obd2b, will everything from the obd2 LS swap just plug in? anything extra i'd have to do?
i already have the correct ECU. i gotta OBD2B ecu jumper with OBD1 LS ecu.
Old Jul 22, 2004 | 11:56 AM
RiceNmotioN's Avatar
Default Re: OBD2 LS swap in OBD2B 00 hatch (2 point 0)
only difference is in the wiring to the ecu. should work the same as long as you use the hatch harness on the motor.
Old Jul 22, 2004 | 02:04 PM
2 point 0's Avatar
Default Re: OBD2 LS swap in OBD2B 00 hatch (RiceNmotioN)
thanks...
pkgwjai082
Feb 1, 2006 07:48 PM
baked_beanz
Jul 24, 2005 02:09 PM
V8K1LLER
Jan 28, 2005 01:11 PM
ted
Dec 30, 2004 09:36 PM
